#1 |
Heater question
95 Mercury Villager. While driving with van at full operating temperature, heat comes out at 2000 rpm but when I stop and rpms drop to 800 the air blows cool/cold. Any idea what might cause this?
#2 |
Heater question
Low on water in the radiator,
Partly pluged up heater core. |
#3 |
Heater question
undeperforming water pump or loose pump belt.
#4 |
Heater question
Could also be vacuum related, whether an engine problem or a faulty or partially crimped line, not having enough to hold the gates open at idle, effectively closing the ducts.
#5 |
Heater question
I am reading up on this and read it could be air in the system. The recommendation is bleed or "burp" the cooling system. The factory service manual I found on-line has detailed instructions on how to do this. I'll give that a try this weekend. Might replace the belt too, while I'm at it.
#6 |
Household Handyman
Heater question
I'm with Dexter II on this one--a vacuum leak. The reason being is that you state that you have heat at 2000 RPM and lose it at 800 RPM. The lower the RPM the higher the vacuum. When you slow down to the 800 RPM area there is more vacuum and this will cause the 'air flow control panels" (doors) to move with more force. Depending on your vehicle a door is either closing or opening at the 800 RPM range and changing the air flow. A vacuum check on the entire vacuum system is at hand.
#7 |
Heater question
From what I understand, the 95 model Villager's blend doors aren't vacuum controlled. I put some coolant in the recovery tank and heating improved. Still checking it out. I found the engine air bleed bolt and heat pipe bleed cap and read up on bleeding the system. I'll try it soon.
| Display Modes | |
| Heater fresh air intake question | Tim142 | HVAC | 4 | 10-15-2012 08:06 PM |
| Question on Carrier Crankcase Heater | Larry H | HVAC | 8 | 12-11-2011 01:24 AM |
| Pilot on Williams millivolt wall heater goes out every 8 to 16 hours | wornways | HVAC | 30 | 06-22-2011 04:29 PM |
| Type B Venting Question For Garage Heater | RoundPorch | HVAC | 4 | 01-03-2010 12:34 AM |
| Garage Heater Wiring ceiling penetration Question | DenverBob | Electrical | 5 | 12-28-2009 02:01 PM |
