Hazy Car Headlights - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-18-2012, 08:10 PM   #1
hazy car headlights
,what is a good home remedy to clean the haze off of your car's headlights
mackbishop is offline   Reply With Quote
Old 10-18-2012, 08:16 PM   #2
Experienced
Jackofall1's Avatar
Go to Autozone and pick a headlight renew kit, they work wonders
Mark
Old 10-18-2012, 08:19 PM   #3
Rewards Points: 150
I wetsand them with 2000 grit paper
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 10-19-2012, 09:41 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Some dupont #7 auto polish and a clean soft rag.
Old 10-19-2012, 12:27 PM   #5
concretemasonry's Avatar
Rewards Points: 2,654
If the haze is from a popped seal and is on the inside, just get a new assembly complete will all new bulbs for about $50.
My 1999 Jimmy SLT had a popped seal got all for about the same amount. Mine had high, low, driving and signals. I had it in when I got an oil change from my mechanic and when he saw the box he installed one unit for no charge because it took about a minute to do.
I felt good until he told me I could bought the same thing 3 blocks down the street without the online freight (regional office with few signs).
Dick
concretemasonry is online now   Reply With Quote
Old 10-30-2012, 10:32 PM   #6
Why don't you visit an auto repair shop? They really can help you out. There is one in my area. Coleman Auto Restoration Systems, I have seen their work its just amazing. I am sure they can treat your headlights too.
Isabell is offline   Reply With Quote
Old 10-31-2012, 06:54 AM   #7
Rewards Points: 304
Works but for the novice Meguires and Mothers sell a kit for about $20.00
polarzak is offline   Reply With Quote
Old 10-31-2012, 12:08 PM   #8
Rewards Points: 131
Here's a fairly detailed write-up from a car forum. It's all pretty standard - getting rid of the haze on the EXTERNAL surface ( like mentioned above, if you have a bad seal and haze is in the inside..... ), just increasingly finer grades of sandpaper.
http://www.lincolnvscadillac.com/sho...ight=headlight
Where this one goes on a tangent is the use of mineral spirits and spar urethane once finished to seal the surface. It's a losing battle once the plastic starts to "dry-rot", you'll be doing it over ( and over ) again as they'll haze over. I polished the lenses on one of my cars crystal clear, and W/I 6 months the worst of the two started getting bad again, now it's just like it was pre-polish.
Chokingdogs is offline   Reply With Quote
The Following User Says Thank You to Chokingdogs For This Useful Post:
concretemasonry (10-31-2012)
Old 10-31-2012, 02:18 PM   #9
Rewards Points: 252
I replace the lens. Try Certi-fit for cheap replacements.
Marty1Mc is offline   Reply With Quote
hazy car headlights mackbishop Automotive Repairs 19 02-01-2013 06:23 AM
What's best for buffing headlights? whfisher Automotive Repairs 16 06-22-2012 10:25 AM
LED headlights billbuilder52 Automotive Repairs 6 05-04-2011 07:59 AM
gmc savanna headlights acglobal Automotive Repairs 1 02-17-2011 05:46 AM
Hazy dusty look on hardwood floor lleegle Flooring 4 07-26-2008 10:04 AM
