Harbor Freight Foldable Trailer - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-02-2012, 11:22 AM   #1
Rewards Points: 768
Anyone have any experience with these? I bought a Tahoe and am getting rid of my truck because I can't convince my wife we need 4 vehicles.....so, I'm thinking of getting a trailer that folds because of a lack of space to store one that doesn't fold. Comments on them?
Also, the hitch receiver is for a 1 7/8" ball....could I swap that out for a 2" receiver since i already have a 2" hitch (ball)?
cibula11 is offline   Reply With Quote
Old 02-02-2012, 11:46 AM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
I have heard of people who like them, and considered one myself before I bought my truck. Just pay attention to the load capacity. If I remember, the folding version is not as capable as the non-folding version - but I could be wrong.
As for the hitch, are you talking about just changing the ball on the hitch, or changing the whole insert... you got me a little confused there. If it's just the ball, go right ahead and swap out the ball for the right one to fit the trailer. They are cheap.
hyunelan2 is offline   Reply With Quote
Old 02-02-2012, 03:24 PM   #3
Rewards Points: 768
The foldable trailer holds around 1200 lbs. and the non folding ones go about 1700 lbs limit.
It's the receiver on the trailer. It is for a 1 7/8" ball, but since I have a 2" ball already, I thought it might be easier to just switch out the receiver.....it would save me a few pennies rather than buying another ball.
Old 02-02-2012, 03:36 PM   #4
hyunelan2's Avatar
Rewards Points: 686
A 1-7/8" ball is $9.99 at Walmart. Less than $7 at Menards. Surely a trailer receiver would cost more than that.
Old 02-02-2012, 04:08 PM   #5
Ironlight's Avatar
Yeah I'm sure the smaller ball is cheaper than the new receiver...unless you already have one laying around that will fit.
I have not used a HF trailer but based on my experience with all their other stuff I would keep a very close eye on the bearings and axle assembly. I think quite a bit of mechanical HF stuff is built like crap and the idea of entrusting 1000# of my stuff to one of their trailers would cause me a bit of anxiety.
Ironlight is offline   Reply With Quote
Old 02-02-2012, 05:04 PM   #6
Rewards Points: 13,250
Just changing the ball is the way to go.
What do you plan on doing with this trailer?
At any given time I have up to 8 differant trailers all for differant uses.
Trailer 101 is buy one to short and it's a royal pain to back up and useless for anything but taking the lawn mower to the shop or a dump run.
I would have to buy some of those fiberglass rods with a flag that go on bicycles to add to the rear of the trailer to be able to not jack knife the trailer when backing up.
Old 02-02-2012, 08:37 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
I bought one and built a teardrop camper on it but I spread the trailer out to 5 feet wide. I was scared of the tongue as it was kinda flimsy but it held up OK. The axle and bearings are good, no problems at all with them. I didn't like the small tires and rims so I bought two 13 inch tires and rims for it. That trailer will do some serious bouncing unless you let some air out of the tires. If you want to go with a 2 inch ball, the coupling on the trailer is bolted on and is easy to change out. HF or Northern Tools have them fairly cheap. I hate changing the ball out so I changed the coupling out.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 02-03-2012, 10:15 AM   #8
Rewards Points: 768
thanks. The foldable trailers now come with 12" tires on the model that I am looking at. I'm guessing that's gonna help the bouncing and overall stability.
Old 02-03-2012, 10:55 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
The one I bought had the 12" tires also, I don't know if they would make a difference or not in bouncing.
Jim
Old 02-03-2012, 11:07 AM   #10
Rewards Points: 768
Well now I'm second guessing myself because I checked the specs on my JD 318 and the mower deck has a width of 57" which would not work with a 4x8 trailer. I'll have to measure when I get home because the wheel base is under 4ft and the deck doesn't seem to be much larger.
Old 02-03-2012, 07:45 PM   #11
A Little Of Everything
Rewards Points: 1,364
I bought this trailer, on a Black Friday Special, for $499. I like it.
http://www.tractorsupply.com/carry-o...pacity-1090202
DrHicks is offline   Reply With Quote
Old 02-14-2012, 01:21 PM   #12
fallrisk's Avatar
I hate the folding trailer with 12 inch wheels. Pay attention to the wheel bearings as they dry out over time. The newer hubs come with a grease booked so its easy to service. I don't trust the Chinese bolts so I replaced most of them with something stronger. I mostly use the trailer to haul my motorcycle to the track and the occasional trip to home depot for building supplies like drywall. It's been 3 years and so far its holding up great and most importantly stores out of the way against my back garage wall. Even made a 2000 mile round trip from bhai to bc with 2 motorcycles on it. There are plenty of better trailers out the there but for the price you cant go wrong. I got mine for less than 300$ from what I remember. Make sure you order an extra wheel for emergencies. On a side note HD customer service is a nightmare, i got a solar panel instead of my spare wheel
fallrisk is offline   Reply With Quote
Old 02-15-2012, 11:58 AM   #13
Rewards Points: 768
You say you hate it, but yet it hold up great and stores nicely? What is to hate? I know it's not the cadillac of all trailers, but sounds like it's done well for most.
Old 02-15-2012, 12:02 PM   #14
fallrisk's Avatar
Haha auto correct. Sorry I love my trailer
Old 02-15-2012, 12:06 PM   #15
fallrisk's Avatar
For more info you should search some motorcycle forums. Tons of people use these.
Edit
Forgot to add... Do your own wiring along the lenth of the trailer esp for the ground wire.
Do we have any trailer gurus in the house? Mr Chips Automotive Repairs 16 08-11-2011 09:29 PM
trailer light wiring issues utilitylocator Automotive Repairs 5 07-01-2011 01:10 PM
trailer in my living room (must read) wengang1 Remodeling 0 01-19-2010 04:30 PM
Trailer Brakes NEED HELP plz Jeepster Automotive Repairs 4 09-13-2009 07:45 PM
New Trailer service hd82 Electrical 10 04-23-2009 01:26 PM
