Hack Tire Pressure Monitor On GM's - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-09-2011, 01:33 PM   #1
Hack tire pressure monitor on GM's
I'm always getting false pressure reports on my GM Montana van.
As this feature cannot be hacked in the computer, I'm thinking of removing the sensors from the wheels and installing them all in the spare wheel.
The GM sensors are part of the valve assembly so all I need do is drill 3 more valve holes in the spare rim and transfer the senders from the wheels. Replace the four valves and I'd be away to the races.
Have I over-looked any considerations in doing this?
Old 01-12-2011, 07:39 PM   #2
Household Handyman
Rewards Points: 1,408
Ummm, Yup ! My understanding, from experience working in an auto parts store and visiting shops--MOST of the TPS units used on auto/light trucks nowadays actually know the tire is rotating. You will get a reading while sitting still in the driveway/parking lot but eventually the 'puter will know the tire is not rotating.
Old 01-12-2011, 11:12 PM   #3
Thanks for the reply! This stirs up a whole bunch of new questions for me.
Where I live its recommended that we should use 4 snow tires in the winter. In fact, in Quebec snow tires are required by law.
In the past I have had my snow tires mounted on rims, to avoid mounting and removing the tires.
To do this with TPS, I will have to buy 4 more sensors.
Another question, is how can my computer tell if its getting a signal from my tires or the one that is parked beside it?
Boiler pressure troubles jduffett HVAC 2 12-12-2010 08:15 AM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 07:04 AM
Older air compressor wiring help lash-1295 Electrical 91 12-23-2009 01:46 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
