GMC 4X4 Wheel Bearing - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-26-2010, 04:41 PM   #1
Has anyone ever changed a front wheel bearing on a 1/2 ton GMC 4X4? I have all the bolts removed and can not free up the bearing.
NY Jim is offline   Reply With Quote
Old 02-27-2010, 10:31 AM   #2
Household Handyman
Rewards Points: 1,408
No, is the answer to the question. But--may I suggest buying a "Chilton" or "Haynes" manual for that truck at your local parts house. This may be valuable on another problem down the road. David
Old 02-27-2010, 11:34 AM   #3
Safe, Most of the Time!!
brokenknee's Avatar
I have not done one either, but I think they may be pressed on. You can usually rent the tools from an auto supply store for a reasonable cost. May want to check out a GMC forum for more detailed information.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 02-27-2010, 11:44 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,030
Ayuh,... What Vintage are we talkin' about anyways,..??
Old 02-27-2010, 12:32 PM   #5
It's a 2001. It is not pressed on, it's bolted with three bolts. I tried half installing the bolts and hammering to no avail.
NY Jim
Old 03-01-2010, 06:37 AM   #6
47_47's Avatar
Rewards Points: 50
Use a 1/2" air chisel, with a mushroom chisel and wear hearing protection.
47_47 is offline   Reply With Quote
Old 03-18-2010, 08:31 PM   #7
Craftsman
It uses a wheel bearing locknut socket that is half inch drive. Our local Autozone sells them for about $15.00. If you have an Autozone nearby they can also print the replacement instructions for you.
Superrick is offline   Reply With Quote
Old 04-14-2010, 11:22 AM   #8
cowboy dan's Avatar
i firmly tap all the way around the hub if u grab hold of hub and jerk it up and down, side to side u should see movement. they are sort of pressed, but once it starts to move u can ten slip a prybar on the edges where the bolts were but instead of prying, just wedge one little pry on the oposite side of the other pryand start turning the prybar. get the prybar in about a 1/4" then work on the other side. it will come free... just swear i bit
before u go too far. your cv axle is held in by a big nut, your bearing and hub should be one assembly. i think it is a 36mm and u need an impaced or someone in the truck on the brakes
cowboy dan is offline   Reply With Quote
comfortmaker rpj2 blower wheel problems nuclearjesus HVAC 3 11-22-2009 08:14 PM
Supporting floor joists on non-load bearing wall? ct9359 Building & Construction 4 07-17-2009 12:59 PM
Bearing wall, HELP me please jamiedolan Building & Construction 7 11-03-2008 11:33 AM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
moving another load bearing nailfun Carpentry 2 02-20-2007 08:10 AM
