Geez, Now Car Quit On The Way To Work.... - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 05-13-2011, 06:34 PM   #1
Rewards Points: 1,062
Geez, now car quit on the way to work....
People,
Just last month yous helped me with a clunk sound- ended up it was the ball joint, and all went well. Now, the car quit whilst driving it. At the last second, I veered off to a driveway and out of traffic. Car towed to my house.
I suspected fuel pump, but I get gas at the injector. Then, I checked for spark, and no spark. (I used a spark tester where you see a flash if theres a spark).
87 pontiac sunbird. I just changed the dist cap and rotor. No engine codes (its an OBD 1).
Thaks!!
noquacks is offline   Reply With Quote
Old 05-13-2011, 06:37 PM   #2
Rewards Points: 268
First thing that comes to mind is the ignition module. Replaced a lot of them over the years.
Marqed97 is offline   Reply With Quote
The Following User Says Thank You to Marqed97 For This Useful Post:
noquacks (05-13-2011)
Old 05-13-2011, 06:48 PM   #3
I appreciate that, Marc, but I have to test it first. Good place to start. I will pull out my Haynes and see what I have to do for a module check.......
Thanks!
Old 05-13-2011, 07:11 PM   #4
checked the module and both + and C terminals check out 12v+. Next........I hope its not the ECM.
Old 05-13-2011, 07:23 PM   #5
fabrk8r
fabrk8r's Avatar
The symptoms sound like the crank position sensor could possibly be defective.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
The Following User Says Thank You to fabrk8r For This Useful Post:
noquacks (05-14-2011)
Old 05-13-2011, 07:30 PM   #6
fabrk8r
fabrk8r's Avatar
BTW, the crank position sensor can easily be checked with an ohm meter as long as you know what the range of resistance should be.
Old 05-13-2011, 07:33 PM   #7
Rewards Points: 558
Check your alternator.
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
Old 05-13-2011, 11:03 PM   #8
Oldguy
Rehabber's Avatar
Your car is not equiped with a crank sensor. 99% chance it's a bad ignition module.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
The Following User Says Thank You to Rehabber For This Useful Post:
Old 05-14-2011, 11:08 AM   #9
Thanks, but are you sure a bad alt can make your car quit in traffic? Battery is still quite powerful. Cranks like mad.
Old 05-14-2011, 11:11 AM   #10
Thaks big time, Rehab. Update: I also suspect module, but kinda still like to test it. I read the Haynes last night in bed, and man, there was over a page and a half of fine print on it! So, what I did a few minutes ago, I put on a spark plug wire directly to the coil main, at the oother end, a spark tester (that lights up ), and touched it to engine ground spot, cranked, and no spark. Doesd this indicate a bad coil? I can test coil easily, I remember, based on Haynes.....
Now, does ignition go direction of module TO coil or coil TO module? If module to coil, then sounds like module for sure. Right? Guess if I dont get a spark from coil main, means coil could still be good if goes from module TO coil.
Thanks!
Old 05-14-2011, 12:01 PM   #11
OK, I get it beter now. Coil tests out good! I did infinity readings and low ohms on the terminals. According to the Haynes, coil is good. Now, looks like module.
I can buy one- thats easy. Probably from Rock auto- but still would like to test it to confirm- for fun. Will do more reading........
Old 05-14-2011, 12:56 PM   #12
Rewards Points: 268
Most auto parts stores can test ignition modules if you take it off and bring it in. Up here all the o'reilly's stores can...they'll do it free if it means selling a module.
Old 05-14-2011, 02:32 PM   #13
Right! Marqed, madderafac, I went to AZ, they tested it and it failed....yahooooo!
So, I bought a new one ($25 or so), lifetime. Im happy. But havnt put it in yet. Storm just hit. Too wet. Gimme an hour or so.
Thanks,
Peole.
Old 05-14-2011, 04:58 PM   #14
Now , the hurrricane is over, so I go out side and open box with module, and instructions clearly state "put on the thermal grease included in box", and NO grease. Geez, I even pointed it out to the TWO attendants behind the counter- they loked at each other and shrugged {I dont thoink you need to smear anything on that].
Gotta go back, now........LOL
Old 05-14-2011, 05:18 PM   #15
Rewards Points: 392
I would make sure the module works before going back just for the grease. New parts have been known to be defective.
rustyjames is offline   Reply With Quote
The Following User Says Thank You to rustyjames For This Useful Post:
grounding the workpiece you're welding jarnold Electrical 43 01-03-2016 07:14 PM
Issues w/ Old Work Box mkrawitz Electrical 5 04-19-2010 11:53 AM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 06:09 PM
