Gauge Light Dimmer - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-28-2009, 09:31 PM   #1
Gauge Light Dimmer
I installed a 25 ohm 3 watt rheostat to adjust my gauge lighting. When on, the rheostat gets extremely hot. I dont know much about electricity, just enough to be dangerous. I am thinking that I can install a 47 ohm .5 watt resistor before the rheostat. What do I need to do to keep the rheostat from overheating?
navman28 is offline   Reply With Quote
Old 10-28-2009, 10:22 PM   #2
For 25 ohms to dissipate >3w you'd need sqrt (3x25) = >9v across it.
How much current do your gauge lights draw when full on? If they are incandescent lamps the calc. for a dimmer resistor gets really tricky. Does the 25 ohms make them dim enough?
Old 10-28-2009, 10:47 PM   #3
I know the gauges are LED but dont know what they draw. Yes they do dim, just the rheostat gets really hot.
Old 10-29-2009, 09:08 AM   #4
LEDs should be easy to control, but you need to measure the current draw at full brightness.
I^2 = 3w/25 ohms so I is at least 0.8 A. That seems high for LEDs.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Light doesn't turn on immediately on dimmer switch Michblaze02 Electrical 3 03-19-2009 06:14 AM
Dimmer didn't work, now old light switches don't work properly townpump Electrical 9 03-16-2008 08:28 PM
OK to user a dimmer with ceiling light? FreeCashBack.co.uk Electrical 2 06-19-2005 10:16 PM
