Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-26-2009, 12:07 PM   #1
Unhappy
Gas pump always shuts off when I attempt to fill up
I have a 92 Ford ranger 6cy 2wd. I have owned the truck since 2002. When ever I attempt to pump gas, I have to thread it in. The pump shuts off if I fully depress the nozzle lever. This is really annoying because it takes so long to fill up. Can anyone help me find the problem ? Oh yeah, this has been happening since 2003.
motown401 is offline   Reply With Quote
Old 09-26-2009, 07:44 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Sounds like the neck vent hole is plugged.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 09-26-2009, 10:35 PM   #3
Remodeler
MinConst's Avatar
Have you tried pulling ot out of the fill tube a little. I've had vehicles where this was helpful.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 09-26-2009, 10:51 PM   #4
I have gas!
Clutchcargo's Avatar
It sounds like the Evaporative System is blocked. Is the check engine light on?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-26-2009, 11:52 PM   #5
Household Handyman
motown401--IF this makes you feel any better: I have a 2007 GMC Sierra that has done this from day one. The dealer(s) I have taken it to tell me that it's just the way it is on this truck. Other owners of '07 and '08 GMC/Chevrolet trucks tell me that they have the same problem. I try to put the nozzle in just enough to get the gas in, but sometimes this will let it spray out, so I'm careful with it. NO WAY have I found a way to just put the nozzle in and let the gas go. Even putting in gas slow will sometimes make it back up and shut off. Most of the stations in my area have the "thingy" removed from the nozzle to allow the handle to stay on anyway. I have been under the truck and there is a vent line from the tank back to the fill pipe, and it is not plugged. Find a solution to this problem and post it please. Thanks, David
Old 09-27-2009, 11:18 AM   #6
Bigplanz's Avatar
Do these vehicles have an anti-siphon device in the gas intake? If so, that will sometimes make it hard to fill the tank with gas without the nozzle shutting off.
Bigplanz is offline   Reply With Quote
Old 09-29-2009, 10:40 AM   #7
Master General ReEngineer
Bondo's Avatar
Ayuh,... I had an 89 F-150, a 88 F-250 diesel that Both did the Same thing,...
Dribbling fuel into them was about all they'd take,..
But only 1 tank on each truck, both the front tanks were the Problem,...
I tried about Everything.... It seems Ford put Too many bends in some fill-pipes,+ it causes a backwash effect...
My 96 F250 diesel Doesn't do it,... Thank you Ford...
Old 09-30-2009, 10:14 PM   #8
Yes the check engine light is on quite often. But it goes out after a minute or so. The only way I fill the tank is dribble the fuel in. I have also tried to pull the nozzle back a little, but I get the same results.
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Sump Pump Questions henlij Plumbing 19 08-12-2009 08:50 PM
Heat pump compressor shuts down bkent HVAC 1 04-20-2009 08:03 AM
What Can I Use to Permanently Fill Holes in Sump Pump "Poly" Tubing? kmcrawford111 Plumbing 12 06-27-2008 08:24 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
