-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   Gas pump always shuts off when I attempt to fill up (http://www.diychatroom.com/f46/gas-pump-always-shuts-off-when-i-attempt-fill-up-53846/)
motown401 09-26-2009 11:07 AM
I have a 92 Ford ranger 6cy 2wd. I have owned the truck since 2002. When ever I attempt to pump gas, I have to thread it in. The pump shuts off if I fully depress the nozzle lever. This is really annoying because it takes so long to fill up. Can anyone help me find the problem ? Oh yeah, this has been happening since 2003.
rusty baker 09-26-2009 06:44 PM
Sounds like the neck vent hole is plugged.
MinConst 09-26-2009 09:35 PM
Have you tried pulling ot out of the fill tube a little. I've had vehicles where this was helpful.
Clutchcargo 09-26-2009 09:51 PM
63 Attachment(s)
It sounds like the Evaporative System is blocked. Is the check engine light on?
Thurman 09-26-2009 10:52 PM
motown401--IF this makes you feel any better: I have a 2007 GMC Sierra that has done this from day one. The dealer(s) I have taken it to tell me that it's just the way it is on this truck. Other owners of '07 and '08 GMC/Chevrolet trucks tell me that they have the same problem. I try to put the nozzle in just enough to get the gas in, but sometimes this will let it spray out, so I'm careful with it. NO WAY have I found a way to just put the nozzle in and let the gas go. Even putting in gas slow will sometimes make it back up and shut off. Most of the stations in my area have the "thingy" removed from the nozzle to allow the handle to stay on anyway. I have been under the truck and there is a vent line from the tank back to the fill pipe, and it is not plugged. Find a solution to this problem and post it please. Thanks, David
Bigplanz 09-27-2009 10:18 AM
38 Attachment(s)
Do these vehicles have an anti-siphon device in the gas intake? If so, that will sometimes make it hard to fill the tank with gas without the nozzle shutting off.
Bondo 09-29-2009 09:40 AM
Ayuh,... I had an 89 F-150, a 88 F-250 diesel that Both did the Same thing,...
Dribbling fuel into them was about all they'd take,..
But only 1 tank on each truck, both the front tanks were the Problem,...
I tried about Everything.... It seems Ford put Too many bends in some fill-pipes,+ it causes a backwash effect...
My 96 F250 diesel Doesn't do it,... Thank you Ford...
motown401 09-30-2009 09:14 PM
Yes the check engine light is on quite often. But it goes out after a minute or so. The only way I fill the tank is dribble the fuel in. I have also tried to pull the nozzle back a little, but I get the same results.
