Fuel Pump - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-22-2008, 06:12 PM   #1
Fuel Pump
How can I be sure that my fuel pump needs to be replaced?
haasjs is offline   Reply With Quote
Old 03-22-2008, 06:31 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Fuel pump for what?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-23-2008, 07:42 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Ayuh,.....
Check it's Pressure,..... If it's Not at Spec,... Change it....
Bondo is online now   Reply With Quote
Old 03-23-2008, 07:43 AM   #4
Building and plumbing
USP45's Avatar
Rewards Points: 150
Furnace?
Gas car?
Diesel car?
Farm tractor?
USP45 is offline   Reply With Quote
Old 03-25-2008, 09:43 AM   #5
Fuel Pump
Sorry guys. It's for a '97 Ranger 4 cyl. I was at a red light, and it just shut off. I tried repeatedly to get going again, but it would not start. The engine turns over, but it won't start. There's also a clicking noise coming from the fuel pump relay.
Old 03-26-2008, 12:43 PM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
This all assumes that a '97 is the same as the older model fuel injected Rangers. There are 2 pumps. A low pressure supply pump in the tank and a high pressure pump that may be inside the frame rail under the drivers seat. (If they didn't move them). First make sure that the safety switch didn't trip. You'll need to look where the reset is. They used to be under the dash at the far right. Not sure about a '97. Check the fuses for the pumps. If that is OK, unhook the supply line going into the high pressure pump. They used to put an in-line fuel filter just ahead of this pump which is a good place to unhook. If you turn the key to the "on" position it should pump fuel. If it does, then relieve the pressure on the shrader valve in the high pressure rail that feeds the injectors. With the key turned to on, use a pressure gauge and it should build pressure. You should be able to tell if the pumps are running or not. If the pumps don't run or run but don't build pressure and nothing is leaking, then get out your checkbook.
Old 03-26-2008, 05:05 PM   #7
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
I'll bet it's inertia switch (fuel cut off switch). When you find it, tap it with a screwdriver. That usually is a temporary solution.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
sump pump issue mikehende Plumbing 15 02-15-2008 06:36 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 02:51 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
Well pump issue-should I be concerned? Mikedks Plumbing 8 10-08-2006 10:42 PM
