Fuel Line Repair - Automotive Repairs - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-30-2013, 08:12 AM   #31
Originally Posted by Shaynecalkins View Post
i was thinking compression fitting too, but auto repair is not my main expertise. alot of time i go to ask for compression fitting for this stuff and the guy get that "deer in the headlights" look and says; you know this is a car,right? not household plumbing. the sizes are all wrong.pfft! compression fitting always works. get me a "sharkbite" dangit ill fix this.(JOKING...DONT DO THAT)
I had to buy a 18" piece of steel line that has the special end with an O ring that fits into the fuel filter has I was not able to form the special end. The other end of the line had no flare; it came with compression fitting to connect to the long steel line. So compression fitting are used on cars. I did double flare it thou, because I can.
Hardway is offline   Reply With Quote
Old 09-30-2013, 08:15 AM   #32
Originally Posted by mj12 View Post
i use 3/8 compression fittings to join those lines. My wife threw that fuel pump away about a year ago, brand new in the box, I could have sent it to you. Now I am Mad all over again
Sent the pump to whom, because if it was the set up I need. I could have picked it up
main waste line repair in basement DKPE Plumbing 1 11-18-2012 07:22 AM
Sewer main line repair question dgeorge Plumbing 4 08-10-2011 07:21 AM
Beckett fuel supply line ThisIsMe HVAC 2 01-31-2010 10:17 AM
Fuel Oil Burner - Pump - 2 line AndrewF HVAC 8 01-25-2010 06:12 PM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 07:10 AM
