Ford Windstar Window Problems - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-19-2012, 10:55 PM   #1
Julius793's Avatar
ford windstar window problems
hi guys my problem is like this, my front driver window sometimes opens sometimes doesnt and sometimes stops in middle. what happens next when i press the botton to open or close it i get a clicking noise coming from the front electronic module (i think). does anyone have any ideas as to what the problem can be and how it can be fixed? thanx julius
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 03-22-2012, 06:32 AM   #2
Rewards Points: 254
You need to check power and ground at the motor. They are common for going bad. They have an internal thermal breaker that cuts out.
cjm94 is offline   Reply With Quote
Old 03-22-2012, 10:55 AM   #3
Check the battery terminals under the hood. Be sure they are clean and making good connections.
If that does not work, do a voltage drop test with a multimeter from the battery + to power going to the motor and from battery - to the ground at the motor. And I mean from the battery POST, not the terminal on the battery post. Someone will need to hold a test lead to the battery post.
For all about this test, search google.com for the words...
voltage drop test
Billy_Bob is offline   Reply With Quote
window performance question renbelle Building & Construction 4 10-06-2010 03:25 PM
Rotted window frame bottom: Do I need to replace the whole window? Ginette Building & Construction 4 09-15-2010 09:52 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Window AC unit problems, Please assist if you can! Boscy HVAC 1 07-28-2005 11:58 PM
