Ford Expidition and F250 Door lock problem
Yes, the latch must come out. It's best to pop all the linkage rods off while it's still bolted up (a pain I know). Then 3 torx bolts. Yeah, remove the one lower bolt on the window track/rail and pull down, the upper is retained by a spring clip (make SURE it get lined up on reassembly or the window will travel very slowly). Then you can finagle the latch out and swap the actuator over. If I remember there are dedicated left & right actuators. Good luck! I'm battling a newer Super Duty with broken exhaust studs right now >:-|
