Ford Contour LX Rear Brake Automatic Adjuster - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-23-2011, 12:26 AM   #1
JJboy's Avatar
Ford Contour LX rear brake automatic adjuster
1999 Ford contour LX (2.0L MFI DOHC 4cyl) _ rear brake shoes - the spring of the automatic adjuster came off. What is the correct position to install automatic adjuster and brake shoes? thanks
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-23-2011, 12:57 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Can you not adjust that once the brake assembly is back together?
Doc Holliday is offline   Reply With Quote
Old 10-23-2011, 01:02 AM   #3
JJboy's Avatar
I'm not sure....I'll check in the morning.
Old 10-23-2011, 01:09 AM   #4
Is that brake fluid all over the place? Did the wheel cyclinder explode? Is it leaking?
Old 10-23-2011, 01:17 AM   #5
JJboy's Avatar
Yes, took me hours to clean everything....both side .......Now I can't put everything together...I need to figure out how to install this automatic adjuster
Old 10-23-2011, 01:23 AM   #6
First rule of drum brakes, do one side at a time so you have one to use as a diagram.
Old 10-23-2011, 01:27 AM   #7
http://www.ehow.com/how_7349330_repl...tor-drums.html
Old 10-23-2011, 01:28 AM   #8
Old 10-23-2011, 01:29 AM   #9
Google image.
Old 10-23-2011, 01:34 AM   #10
JJboy's Avatar
I did this, but the adjuster is behind everything...... I have access to Alldata ...... but does not help also......
Old 10-23-2011, 04:05 PM   #11
Do you have a "u pull it" parts place nearby? You could pull a drum off and see the assembled version.
Master of Cold is offline   Reply With Quote
Old 10-23-2011, 06:21 PM   #12
JJboy's Avatar
I finally managed to install the automatic adjuster ....
Old 10-23-2011, 06:57 PM   #13
you know the rules, pics or it didn't happen.
Old 10-23-2011, 07:05 PM   #14
JJboy's Avatar
LOL
Old 07-28-2012, 09:27 PM   #15
Do you remember how to set the adjuster???
Pedrin is offline   Reply With Quote
Ford Contour 99 LX P1071 JJboy Automotive Repairs 3 01-15-2011 01:39 AM
Ford Contour 99 LX parts identification JJboy Automotive Repairs 0 10-23-2010 07:33 PM
rear brake piston rcm5835 Automotive Repairs 8 12-02-2008 04:00 PM
1966 Ford Mustang Rear Main Seal SCHOONER Automotive Repairs 4 11-23-2007 07:40 AM
