-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   Ford Contour LX rear brake automatic adjuster (http://www.diychatroom.com/f46/ford-contour-lx-rear-brake-automatic-adjuster-120976/)
JJboy 10-22-2011 11:26 PM
http://www.fordforum.org/style_image...dpr/spacer.gif
1999 Ford contour LX (2.0L MFI DOHC 4cyl) _ rear brake shoes - the spring of the automatic adjuster came off. What is the correct position to install automatic adjuster and brake shoes? thanks
http://img12.imageshack.us/img12/7991/photo19ly.jpg
Doc Holliday 10-22-2011 11:57 PM
Can you not adjust that once the brake assembly is back together?
JJboy 10-23-2011 12:02 AM
I'm not sure....I'll check in the morning.
http://img41.imageshack.us/img41/1552/photo21nd.jpg
Doc Holliday 10-23-2011 12:09 AM
Is that brake fluid all over the place? Did the wheel cyclinder explode? Is it leaking?
JJboy 10-23-2011 12:17 AM
Yes, took me hours to clean everything....both side :( .......Now I can't put everything together...I need to figure out how to install this automatic adjuster
Doc Holliday 10-23-2011 12:23 AM
First rule of drum brakes, do one side at a time so you have one to use as a diagram.
Doc Holliday 10-23-2011 12:27 AM
http://img.ehowcdn.com/article-page-...ms-800x800.jpg
http://www.ehow.com/how_7349330_repl...tor-drums.html
Doc Holliday 10-23-2011 12:28 AM
http://www.signalautoparts.com/secti...ning-valve.jpg
Doc Holliday 10-23-2011 12:29 AM
Google image.
http://www.2carpros.com/forum/automo...99_brake_4.jpg
JJboy 10-23-2011 12:34 AM
I did this, but the adjuster is behind everything...... I have access to Alldata ...... but does not help also......
Master of Cold 10-23-2011 03:05 PM
Do you have a "u pull it" parts place nearby? You could pull a drum off and see the assembled version.
JJboy 10-23-2011 05:21 PM
I finally managed to install the automatic adjuster ....:thumbsup:
Doc Holliday 10-23-2011 05:57 PM
you know the rules, pics or it didn't happen. :laughing:
JJboy 10-23-2011 06:05 PM
LOL :thumbup:
Pedrin 07-28-2012 08:27 PM
Do you remember how to set the adjuster???
Originally Posted by JJboy (Post 754488)
http://www.fordforum.org/style_image...dpr/spacer.gifDo you remember how to set the adjuster???
