Ford Contour LX P0171 - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-24-2011, 03:22 PM   #1
JJboy's Avatar
This code shows up for the past 2 years. Car is running great. During this time, I have replaced O2 sensor, clean MAF sensor, smoke test with no leak. No one are able to find what is causing this f**** code to come up.
I used the OBDCOM software to save the sensors when I was driving the car. Please let me know if you cold find any problem. Thanks
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-24-2011, 03:32 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
You don't have a vacuum hose leaking somewhere, do you? I had a vac hose come off of a defroster damper once that caused a lean engine code.
Old 10-24-2011, 03:43 PM   #3
JJboy's Avatar
I used a smoke machine and I couldn't find any leak. Also another mechanic did the same test. I will check the defroster damper....
Old 10-24-2011, 03:45 PM   #4
While you are doing the test, switch the AC/heater controls all around. There are at least 2 vacuum controlled dampers.
Old 10-24-2011, 03:55 PM   #5
JJboy's Avatar
these????
Old 10-24-2011, 05:56 PM   #6
Rewards Points: 254
Check for cracked boots on any breather tubes on the valve covers. This will cause unmetered air from the maf sensor and not cause driveability issues.
cjm94 is offline   Reply With Quote
Old 10-25-2011, 06:53 AM   #7
Originally Posted by JJboy View Post
these????
Yeah that's what they look like.
Old 10-31-2011, 08:47 PM   #8
Last but least the one thing that most of the time that causes this code with idle search. Would be the mass air flow sensor.. Check the air fuel correction with the 0/2 sensors.. I'm sure you will find the problem will be the MAF.. It will need to be replaced..
Mack daddy is offline   Reply With Quote
Ford Contour LX rear brake automatic adjuster JJboy Automotive Repairs 14 07-28-2012 08:27 PM
Ford F150 blower issues marippe Automotive Repairs 1 03-10-2011 02:50 PM
Ford Contour 99 LX P1071 JJboy Automotive Repairs 3 01-15-2011 12:39 AM
Ford Contour 99 LX parts identification JJboy Automotive Repairs 0 10-23-2010 06:33 PM
1998 Ford ranger electric problem fmg741 Automotive Repairs 5 09-24-2008 12:24 PM
