Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-17-2010, 09:03 PM   #1
JJboy's Avatar
Ford Contour 99 LX P1071
I'm trying to fix the code P0171 on the99 2.0 LX myself. The car is running perfectly. It has new O2 sensors, sparks, spark plugs, full clean injectors. I don't see any
or loose/cracked hoses.
I need some tips on to how to do a better tests on vacuum leak, PCV valve and ERG valve.
The has been running for 2 years with P0171 on it and doesn't have performance problems.
Thanks all.
JJboy is offline   Reply With Quote
Old 10-18-2010, 07:07 AM   #2
Bigplanz's Avatar
Check your PCV lines very carefully. Look for a rubber elbow connection somewhere in the line. Replace it. They crack/leak a lot on Fords.
Here's a good link that covers the subject pretty well.
http://www.aa1car.com/library/ford_lean_codes.htm
Bigplanz is offline   Reply With Quote
Old 10-18-2010, 11:50 PM   #3
JJboy's Avatar
Thanks, I'll check that.
Old 01-15-2011, 01:39 AM   #4
Try this link http://www.obd-codes.com/ it might help you figure out the bug in your car, I've been having that resources ever since I had a car bug.
_________
ford parts
paulrichmond is offline   Reply With Quote
Need 1979 Ford ltd service manuel thumpermiller Automotive Repairs 5 08-31-2010 04:28 AM
93 Ford Ranger A/C problem robcourtis Automotive Repairs 1 06-14-2010 10:20 PM
Ford diesel API oil ratings Superrick Automotive Repairs 4 03-18-2010 09:13 PM
DIY Question - 2000 Ford Explorer diyford Automotive Repairs 4 01-13-2010 04:20 PM
ford galaxy front wiper motor (electrical diagramme ) yellrebel888 Automotive Repairs 4 01-14-2008 03:18 PM
