Fog Machine As A Smoke Tester. - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-18-2010, 08:24 PM   #1
JJboy's Avatar
Fog machine as a smoke tester.
I was considering doing a smoke test to find a vaccum leak. Can I use a party fog machine? Has anyone done anything like this before or does anyone has any suggestions?
Thanks All.
JJboy is offline   Reply With Quote
Old 10-25-2010, 07:30 PM   #2
First off what kind of car are you dealing with? Why do you think that you have a vacuum leak?
BryantS is offline   Reply With Quote
Old 10-25-2010, 10:21 PM   #3
JJboy's Avatar
It is 1999 Ford Contour LX with P0171. The car is running ok.
Old 10-26-2010, 04:37 AM   #4
lean bank 1. Assuming this is a 4cylinder. If so I would check the gummyness of the pcv hose. If this is a v6 I would check to see if the imrc is working correctly.IMRC= intake manifold runner control. Lots of times also the little white clips that hold in the rods brake and fall out. You could also clean the mass air meter.
Old 10-26-2010, 08:46 PM   #5
JJboy's Avatar
Thanks BryantS. It's 4 cyl. I cleaned the MAF sensor. I can't find PCV and EGR valve.
Please check this picture and let me know if you recognizes the parts. Thanks again.
http://img829.imageshack.us/img829/6379/pic1zw.jpg
Old 10-27-2010, 06:21 PM   #6
I can't remember off the top of my head where the valve is but under your hood you should have a vacuum diagram and it should tell you there. I would have told you that it wraps around under the t-stat but it doesn't look like it does on the contours. I have a 2000 zx2 with the same motor but mine is under the front right corner under or beside the exhaust manifold.
Old 10-27-2010, 06:56 PM   #7
JJboy's Avatar
I can't find.
Old 10-28-2010, 07:29 PM   #8
I am suspecting right behind the throttle body on the intake manifold.
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Smoke Alarms Just Would Not Stop lundyg Electrical 2 12-30-2009 08:09 AM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 09:22 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
