Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-06-2011, 03:26 PM   #1
f150 truck
a/c done - can i still drive it with no a/c on?
chdairy7@aol.co is offline   Reply With Quote
Old 08-06-2011, 05:41 PM   #2
f150 truck
Yes, roll down the windows
Broughton is offline   Reply With Quote
Old 08-06-2011, 05:44 PM   #3
Wire Chewer
Red Squirrel's Avatar
f150 truck
It will be like being in the 6th layer of Hell, but you should be fine.
Old 08-06-2011, 05:58 PM   #4
Experienced
Jackofall1's Avatar
f150 truck
What do you mean, no air, you still have 2/60 air.
(2) windows down
(60) miles per hour
Old 08-08-2011, 01:56 PM   #5
Tizzer's Avatar
f150 truck
When did F150s become appliances?
Tizzer is offline   Reply With Quote
Old 08-08-2011, 07:18 PM   #6
An old Tradesmen
f150 truck
Moved to Automotive Forum.
Old 08-08-2011, 08:37 PM   #7
f150 truck
as long as the compressor didn't lock up, you will be fine. If its locked up you will need to remove the belt. If its just one belt for the entire engine, then you may need to buy a new belt for a no ac option and bypass the compressor pulley. Again, this is only if the compressor locked up and won't allow the pulley to turn.
D-rock is offline   Reply With Quote
Old 08-09-2011, 06:29 AM   #8
DIY Hack
Mr Chips's Avatar
f150 truck
When the A/C's die in August they are reclassified as toaster ovens
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Legal weight limit for my dump truck dnh082461 Building & Construction 4 11-04-2010 07:45 PM
Truck ants Thurman Pest Control 17 08-29-2010 08:50 AM
Can a concrete truck get into my back yard? J S Machine General Discussion 55 05-22-2010 01:11 PM
cement truck over sewer line SAS Plumbing 20 03-24-2009 10:07 PM
50amp GFI Trips on Commercial Truck djeffwhite Electrical 1 03-10-2008 02:04 AM
