F150 Ac - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-25-2013, 10:32 AM   #1
Rewards Points: 16
F150 ac
Cant seem to figure this out, my truck will randomly start to blow warm air. It has been evacuated and replaced FOV and weight charged. Sometimes regardless of time of day, the ac works without issue. But other times you can get in and it wont cool past 50 degrees.
When it does this, the low side is always cold and sweating as it should be and the clutch is still engaged? Its not like the clutch is cycling out.
Thoughts?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 07-25-2013, 01:52 PM   #2
Rewards Points: 254
What year probably a temp blend door actuator if its a newer truck
cjm94 is offline   Reply With Quote
Old 07-25-2013, 02:02 PM   #3
Rewards Points: 16
2008 and sorry forgot to say the b door motor as been replaced.
Old 07-25-2013, 04:44 PM   #4
Rewards Points: 254
Is it dual zone they have two. One for each side. Could be a bad actuator right away. If it was plugged in before it was bolted down its junk it ruins the position sensor. I have seen the blend doors break loose. The control head could be bad but not real common.
Old 07-25-2013, 04:50 PM   #5
Rewards Points: 16
No dual zone
Was not plugged in prior to install
Old 07-25-2013, 07:07 PM   #6
Rewards Points: 254
Hard to say without looking at it. Sounds like an actuator issue.
The Following User Says Thank You to cjm94 For This Useful Post:
digitalplumber (07-25-2013)
Old 07-25-2013, 10:52 PM   #7
ukrkoz's Avatar
Rewards Points: 932
Clutch not cycling means system goes into overload and shuts off. Pressure releases, it cycles back to norm.
CLUTCH MUST CYCLE. Period.
ukrkoz is offline   Reply With Quote
Old 07-25-2013, 11:06 PM   #8
Rewards Points: 16
OK sounds great, what do I look for?
Old 07-26-2013, 12:03 PM   #9
47_47's Avatar
Rewards Points: 44
What is the rh, ambient air and the discharge air temp? You probably have a variable displacement compressor and they do not cycle off and on.
47_47 is offline   Reply With Quote
Old 07-26-2013, 12:09 PM   #10
Rewards Points: 16
We are in the mid 90's here in Houston, seems to do this more on the very hot days with high humidity.
Left out this morning at 89 degrees out and had about a 44 degree discharge temp. No issues did not start to blow warm.
Its so random but appears to do it more on the very hot days which would be high humidity, high temp.
When it starts acting up, the discharge temp will rise to 50.
2008 F150 Lariat 5.4
Old 07-26-2013, 02:17 PM   #11
47_47's Avatar
Rewards Points: 44
50 outlet temp may be normal on high humidity and temperature days.
Need to make a note of the conditions when it won't get below 50.
Ambient air temp
RH
Actual outlet temp.
Are you idling or stuck in traffic when this happens? Low air flow over the condenser will give warmer outlet temps.
Did you change temperatures? Check blend door or actuator
Pop the hood. Is the low side of the system freezing? Condensation and cold is normal, not freezing.
Old 07-26-2013, 02:39 PM   #12
Rewards Points: 16
Ambient air temp
RH
Actual outlet temp.
50 cant be normal, when its not acting up it gets down to 42, like yesterday and the truck thermometer said 108. Cab was nice and cool.
Just went to UPS and it would not go below 50, wont cool interior at that its only 95 right now.
Happens under both scenarios: Traffic and or on road.
Nope got in started truck and its on, t stat set at 60.
Not frozen.
F150 A/c compressor chdairy7@aol.co Automotive Repairs 1 08-06-2011 05:18 PM
Ford F150 blower issues marippe Automotive Repairs 1 03-10-2011 03:50 PM
1998 F150 or 1997 Silverado Z71? jpearson311 Automotive Repairs 8 09-30-2010 03:00 PM
New rotors on my F150 were junk ! budedm Automotive Repairs 10 12-28-2009 04:11 PM
88' F150 heater core elscorcho Automotive Repairs 3 10-26-2008 10:43 PM
