F-150 Front End!! - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-12-2013, 05:42 AM   #1
Rewards Points: 164
F-150 front end!!
I have a 90 f-150 4x4 v8 302 I need to do ball joints, and tie rods, this is the first time doing a ball joint that needs to be pressed, I have proper tools, anyone can help with some guides or tips would be great like should i replaced the bearings, tips anything to make this smoother, thank you in advance...
bostonwindows30 is offline   Reply With Quote
Old 10-12-2013, 07:10 AM   #2
Rewards Points: 254
Clean and inspect the bearings. Should be fine with repacking replace the axle ujoints while you have it apart. Good luck getting the spindle out they seize in its the worst part. They make a socket that threads on the spindle and attaches to a slide hammer. Makes life a lot better.
cjm94 is offline   Reply With Quote
Old 10-12-2013, 09:45 PM   #3
Rewards Points: 164
Will do, thanks man!!
Old 10-13-2013, 08:29 AM   #4
Rewards Points: 164
Can I change the ball joints with out taking off bearing assembly???
Old 10-13-2013, 08:31 AM   #5
Rewards Points: 164
Can I just pop off the knuckle??
Old 10-13-2013, 10:39 AM   #6
Remodeler
Rewards Points: 302
With the 4x4 you have to pull the lockout assembly, then the hub and wheel bearings. This gets you to the spindle and backing plate, you have to remove that to allow you to pull the axle shaft. Once you have the axle out then you can remove the steering knuckle and change the ball joints. The spindle has a needle bearing and seal inside, don't forget to clean, inspect and pack the bearing with grease.
iamrfixit is online now   Reply With Quote
Old 10-13-2013, 10:50 AM   #7
Rewards Points: 164
Okay gotcha, perfect alot of work but got to do it..
Old 10-13-2013, 05:47 PM   #8
ukrkoz's Avatar
Rewards Points: 932
http://www.autozone.com/autozone/rep...96b43f8038ecc6
ukrkoz is offline   Reply With Quote
Squaring a walkway off the front steps? Boiler98 Building & Construction 3 07-14-2012 09:31 PM
Replacing a concrete front door approach with a boardwalk? bigdaddydavy Building & Construction 10 05-31-2012 10:08 PM
Help with paint colour for the garage and front door syndicate1 Interior Decorating 7 07-25-2010 07:08 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 11:46 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 01:47 PM
