Ever Install A Door Spring On A 2 Door? - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-11-2011, 05:44 PM   #16
Household Handyman
Rewards Points: 1,408
No need to remove the door. One important thing missing here, and easily obtained: safety wire in the .045" range. Meaning close to that. Do use a vice to compress the spring, use the safety wire to tie the spring closed in three (3) positions such as 2 o'clock, 6 0'clock, and 10 0'clock. The wire goes lengthwise through the spring, enough out each end to wrap back together and tie together tightly. The spring should, and I'm betting so, go back in the door hinge now with a little "fudge" room to spare. Slightly close the door to make the spring contact on each end. Cut the safety wire off, pulling it out probably with needle nose pliers. Done this so many times I can do it blindfolded. Once you get the hang of this, I'll tell you about using pennies to remove a hood hinge spring safely, blows your mind away. OH--and next time, don't remove the door to replace the hinge pins. Do ONLY one pin at the time, use a jack to support the door, have the door at a 45 degree open angle and I'll bet it works.
The Following 2 Users Say Thank You to Thurman For This Useful Post:
Leah Frances (09-11-2011), noquacks (09-17-2011)
Old 09-11-2011, 07:25 PM   #17
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
I've used the same type of spring compression tool you have and have never had a problem. are you sure you are using it correctly?
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
The Following User Says Thank You to Mr Chips For This Useful Post:
Old 09-12-2011, 06:30 PM   #18
Bigplanz's Avatar
Rewards Points: 996
The compressor I have looks like the one in the picture. It worked on a beretta door spring. If you can support the door from above like in a garage from a rafter the job goes so much easier. The spring was lots easier than replacing the pins.
Bigplanz is offline   Reply With Quote
The Following User Says Thank You to Bigplanz For This Useful Post:
Old 09-17-2011, 06:26 AM   #19
Rewards Points: 1,062
Well, OK, a new source of inspiration. I could try this right this morning, actually. Where do you get this "safety wire"? I have some heavy wire- guess its easy to measure the thickness.....
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 09-17-2011, 06:29 AM   #20
Right, Chips, its just that once I squash the spring to the max (no more else to compress) the width of the compressed spring is STILL too wide to fit into the door "pins". Thats my big dilema.
Exterior door install on a crooked wall ihoven Windows and Doors 8 05-19-2014 03:03 PM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 06:50 AM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
How to install a door? karen_b Carpentry 5 10-17-2010 06:13 PM
How to install wood screen door and exterior steel door orange Remodeling 2 07-16-2010 12:00 PM
