Ever Hear Of AT Fluid Called SP III? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-06-2013, 08:13 PM   #1
Rewards Points: 1,062
Ever hear of AT fluid called SP III?
Trying to plan for a fluid change for a Kia 2011 Soul. Heard (like Honda likes to do) you gotta use Kia brand ONLY, or the devil will poke you with a fork, in Hell, when you die. Trying to be edjukatid more on this. Then, I hear theres an AT fluid spec called SP-III, which some say is what I need.
AZ also told me they spec out a "Dex/Merc blend for this year Kia. Man, a blend??
Im so new at this, people. Comments/advice apreciated!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 09-06-2013, 08:13 PM   #2
oh- no luck on Kia's site, specificatons. maybe im not looking hard enough....sheesh.
Old 09-06-2013, 09:03 PM   #3
Rewards Points: 13,300
http://www.valvoline.com/products/br...ssion-fluid/37
Old 09-06-2013, 09:17 PM   #4
nice link, joe. Still, need proof my Kia uses this.......didnt see it listed on link.....(did I miss it??)
Old 09-06-2013, 10:43 PM   #5
ukrkoz's Avatar
Rewards Points: 940
Well, on Honda, they do sell aftermarket fluid available. Blue cans. Clearly says made for Honda vehicles. But then dealership price is not much different, so why bother. I simply go with Amsoil, pricy as it is, but lasts helluva longer than any other ATF.
Applications
AMSOIL Signature Series Multi-Vehicle Synthetic ATF
is recommended for transmissions, hydraulics, power steering systems and other applications that require any of the following specifications:
Ford MERCON®, MERCON® V, ESP-M2C166-H; GM DEXRON® III; Chrysler ATF+4®, MOPAR® AS68RC; Allison C-4, TES-389; Audi G 052 162, G 052 990, G 055 025; BMW 7045E, LA 2634, LT 71141; Honda ATF-Z1 (not CVT); Hyundai SP-II and SP-III; Idemitsu K17; JWS 3309, 3314, 3317; Kia SP-II and SP-III, ATF Red-1; MAN 339F, 339 V1, 339 V2, 339 Z1, Z2 & Z3; Mazda ATF-M III, ATF-MV; Mercedes Benz 236.1, 236.2, 236.3, 236.5, 236.6, 236.7, 236.9, 236.10, 236.11, 236.81; Mitsubishi SP-II and SP-III; Nissan Matic-D, Matic-J, Matic-K; Shell 3403, LA 2634; Subaru ATF, ATF-HP; Suzuki 3314 & 3317; Texaco ETL-7045E, ETL- 8072B, N402; Toyota Type T-III and T-IV; Voith 55.6335.XX (G607), 55.6336.XX (G1363); Volvo 97340, 97341; Volkswagen G 052 162, G 052 990, G 055 025; ZF TE-ML 03D, 04D, 05L, 09, 11B, 14A, 14B, 14C, 16L, 17C.
ukrkoz is offline   Reply With Quote
Old 09-07-2013, 09:42 AM   #6
This is sometimes a tricky decision. Some manufacturers tune the shifts with clutch material, others use fluid with different friction modifiers to tune the shifts.
That's why there are different fluids.
RoyalAcresRod is offline   Reply With Quote
Old 09-07-2013, 08:25 PM   #7
ukrkoz's Avatar
Rewards Points: 940
I can only vouch for Amsoil. pretty much, it's replace it and forget it fluid. Good for about 100 000 miles. rear diff, t-case - same. Used their product for years on lexi, Hondas, Toyota. never an issue. Pricy. Well worth it.
Old 09-22-2013, 08:27 PM   #8
cocobolo's Avatar
Rewards Points: 5,674
Phone your local Kia dealer and ask them directly. Why mess around?
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
BEHR would like to hear about your experiences with our paint chris.behr Painting 68 08-02-2009 04:37 AM
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 08:46 AM
Flooring vs Subflooring (whatever it is called) lifeontherun Flooring 3 07-13-2008 04:03 PM
Flooring vs Subflooring or whatever it is called lifeontherun Flooring 10 07-09-2008 09:14 PM
What is this part of the gutter called? DanBress Roofing/Siding 4 11-04-2007 08:41 PM
