Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-03-2009, 07:42 AM   #1
sweaty
Engine Light, Steering Fluid
I have a 2000 Ford Taurus Wagon with the OHV "Vulcan" engine, 102000 miles. Coming home, I noticed a little steering noise. After my wife drove it the next day, the engine light came on. The steering fluid was very low, I filled it up, and the noise went away. The engine light is still on.
Is it a coincidence that the light came on when the steering fluid was low? I checked the level recently and never saw red fluid on the garage floor. What should I do now?
sweaty is offline   Reply With Quote
Old 08-03-2009, 09:06 AM   #2
47_47's Avatar
I think it is just a coincidence. You should check for codes to be sure. The ps fluid may be accumulating inside the rack bellows boots.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Old 08-09-2009, 12:27 PM   #3
Drywall contractor
I don't think the power steering would give you a code either. I've got a '99 Chevy pickup and the wife has an '01 Chevy van, both of which have power steering leaks and make noise when low. Never got a code from either. Most auto parts stores will scan the codes for free.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-09-2009, 08:36 PM   #4
The PS won't throw a code. If it was low and making noise I'd flush it out and put new fluid in it.
Go by any Autozone and they'll check the code and give you the number. Then they can turn it off and you can look up what it means online. Drive it a while and see if it comes back on.
AdRock is offline   Reply With Quote
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
power steering fluid leak :( pesphoto Automotive Repairs 5 09-24-2008 01:19 PM
Check Engine light Code P0430 Ford Explorer Mr Chips Automotive Repairs 4 04-09-2008 12:02 PM
