Durango Radio /turn Signal Problem - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 05-04-2009, 10:55 PM   #1
Rick
Durango radio /turn signal problem
My problem, when driving and I hit a big bump, my radio and turn signals stop working. But if I pull over and shut the truck off they work just fine. What could the problem be?
lemoncoke is offline   Reply With Quote
Old 05-04-2009, 11:31 PM   #2
Learning by Doing
Leah Frances's Avatar
Check your fuses for each item just to make sure nothing's loose.
Check/replace relays for turn signals etc. I'd guess it's a couple of failing relays.
For a while my volvo's turn signals would only work if I put my brights on first. $2 worth of relays at the pick-and-pull later - no problem.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-06-2009, 05:45 AM   #3
Intermittant electrical problems can be a nightmare to diagnose. From your description, it sounds like both circuits may have a common voltage feed. First thing I would do is to check all the connections at the radio amd turn signal wiring. Most circuits have pin type connectors now, and it dosen't take much to cause intermittant voltage drop. Look for loose or corroded terminals and make sure all connectors plug in securely.. This is one of those problems that might have to get worse before you can fix it..
frazierdavidson is offline   Reply With Quote
Old 05-06-2009, 09:04 PM   #4
Check the wires at the ignition switch connector. Also when the radio and turn signals go out, wiggle the key, do they come back on? Sounds like an ignition switch issue. I have seen it before, I work on them for a living. Good Luck.
kchopper is offline   Reply With Quote
Old 05-06-2009, 09:11 PM   #5
Rick
Had the ignition switch replaced a couple of years ago. The problem didn't start till awhile after that.
Old 05-07-2009, 11:14 AM   #6
47_47's Avatar
Rewards Points: 50
I've seen this also. What could be happening is the ignition lock cylinder is turning slightly from the run position, especially with a lot of keys on the ring.
47_47 is offline   Reply With Quote
Old 06-10-2009, 03:01 PM   #7
If you can reliably reproduce the problem it will be easier to trace key points with a voltmeter.
If not, do what I did.
Buy a few 2v LEDs with 510 ohm resistors and hook up each to a junction in your car's wiring. If all the LEDs are on, you are getting voltage at each junction.
Post a schematic of your vehicle and we can all help with deciding on good test points.
When I hooked up the circuit to test it, the fault showed up and I immediately knew where the problem was (in my case, bad contacts on the clutch interlock relay).
Radio Fence Pet Fence Repair Wrangler08 General DIY Discussions 3 01-01-2011 01:25 PM
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 11:00 AM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
