Driver Wiper Not Working After Coldd - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-02-2011, 09:15 PM   #1
Driver wiper not working after coldd
Two mornings ago it was very cold (around 10 degrees)
after scraping up my windows and loosening the wipers from being frozen to the windshield, i drove however, when i ran them the wipers the driver side only when up about 1-2 inches, the passenger side ran as normal.
I thought it might just be the cold, but it warmed up to around 35 today and it is still doing the same thing?
caseynshan is offline   Reply With Quote
Old 12-02-2011, 09:34 PM   #2
Rewards Points: 13,270
Where the bottom of the wiper arm it attached to the shaft there's a metal cap that can be unclipped once it's flipped up tighten the nut holding the arm on. If that does not work remove the arm and see if the spline or the hole in the arm is striped.
Old 12-05-2011, 06:34 AM   #3
Rewards Points: 274
One of the arm ball mounts could have popped out of the neoprene joint. If you are luicky you may be able to pop it back in, but generally if this has happened the neoprene is usually cracked and unserviceable. You don't say what kind of vehicle, but I have have seen this in a couple of GMs.
polarzak is offline   Reply With Quote
Old 12-05-2011, 07:59 PM   #4
A Little Of Everything
Rewards Points: 1,364
That's where my money is!
Those wiper arms are made of soft metal. It's very common for the nut to loosen enough, or for them to strip out enough, that the wiper arm won't move.
I've never had a wiper arm fail to move if I tightened up the nut.
DrHicks is offline   Reply With Quote
Old 12-06-2011, 03:39 PM   #5
raylo32's Avatar
Rewards Points: 1,238
Concur... been there done that. These almost always can be fixed with a simple tightening.
raylo32 is offline   Reply With Quote
Old 12-06-2011, 03:55 PM   #6
Common knowledge among those of us who drive old crap!
Old 12-06-2011, 03:59 PM   #7
raylo32's Avatar
Indeed! Good thing they build 'em tough... at least in this particular detail.
Water Filled Gas Furance Not working szym0n HVAC 1 02-21-2011 05:46 AM
Receptacle stopped working lovetobuild Electrical 3 02-11-2011 11:05 AM
Some things not working on a circuit while others are? speedster1 Electrical 7 11-24-2010 07:23 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
