Dripping Muffler - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-24-2014, 08:06 PM   #1
Rewards Points: 346
Dripping muffler
Hi everyone.
Went to look at a used truck today, it appears to be in excellent shape (as far as the frame and undercarriage go). When he put it on the lift and brought it up, water was leaking out of the front of the muffler....he said that was nothing to worry about. They all say that about EVERYTHING, lol!
Is it anything to worry about? The truck has sat for most of the winter, if that helps any.
Thank you!
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 03-25-2014, 12:08 AM   #2
Remodeler
Rewards Points: 316
Some water is normal, will be most noticeable when driving short trips where the engine does not reach full operating temperature. The catalytic converter that is just ahead of the muffler contains a catalyst that actually converts CO and unburned hydrocarbons into CO2 and water as the vehicle is driven. Once the vehicle has been driven long enough to fully reach operating temp the moisture is mostly burned off. As the exhaust cools back off after being driven water tends to condense and collect in the muffler.
iamrfixit is offline   Reply With Quote
Old 03-25-2014, 07:33 AM   #3
Rewards Points: 1,294
Most water in exhaust systems is from condensation. A cool exhaust system does not allow for the hot gasses to maintain the water as vapor. As the gas moves thru the system it condenses out and lays in the pipes and muffler. As the system warms up, the water stays in a vapor state as the dew point is exceeded. Once the system is hot enough, it will also evaporate all the excess water in the system as well. Starting the truck up and driving it into the shop probably produced about a half quart of water that mostly went out the pipe. However due to the cold system some of it condensed out and collected in the muffler
danpik is offline   Reply With Quote
Old 03-25-2014, 07:53 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,834
Normal part of combustion. That is why they typically have hole/drains in the mufflers.
Old 03-25-2014, 08:04 PM   #5
ukrkoz's Avatar
Rewards Points: 934
Yep^^^^^ That's what the peep hole is for.
ukrkoz is offline   Reply With Quote
Old 03-25-2014, 10:38 PM   #6
Rewards Points: 220
yep. not only normal, but good. if it didn't leak, the water would stay in there and rust out the muffler faster.
Fix'n it is offline   Reply With Quote
Old 04-02-2014, 01:11 PM   #7
Low Slope Roofing
Rewards Points: 114
My 05 will leak most of the time, so does dad's 12. when it's idling. No cause for concern like others stated, that is unless you can hook a garden hose up and water the yard with the flow.
1985gt is offline   Reply With Quote
Old 04-02-2014, 03:59 PM   #8
Rewards Points: 1,208
Ahem: Excuse me but if the "condensation" continues long after warm up, and continues very long. You have a blown head gasket, cracked cylinder head, cracked cylinder wall. one of these or all of these.
RUN
ED
de-nagorg is online now   Reply With Quote
Old 04-02-2014, 04:20 PM   #9
Low Slope Roofing
Rewards Points: 114
Originally Posted by de-nagorg View Post
Ahem: Excuse me but if the "condensation" continues long aftyourarm up, and continues very long. You have a blown head gasket, cracked cylinder head, cracked cylinder wall. one of these or all of these.
RUN
ED
Water is a byproduct of the combustion process. Its in a vapor form unti it jas a chance to condense in the exhaust system.
A blown head gasket or a problem like you described you would see coolant mixed with youe oil or a lot of white smoke coming out of the tail pipe.
Old 04-02-2014, 05:05 PM   #10
not necessarily!
ED
Old 04-02-2014, 05:12 PM   #11
Low Slope Roofing
Rewards Points: 114
The coolant would then have a passage to the combustion chambet and/or oil and vice versa. It would be seen somewhere oil, exhaust, or ground. Or you would have oil in th coolant
Old 04-02-2014, 05:17 PM   #12
And again NOT NECESSARILY!
Old 04-02-2014, 05:18 PM   #13
Low Slope Roofing
Rewards Points: 114
Where would it go?
Old 04-02-2014, 05:32 PM   #14
A fact: last fall I had to replace the heads on my ride. due to the coolant was going somewhere but not in the oil, the oil was not going into the coolant either.
Seems that there was a microscopic crack in each head, that was only leaking coolant after warm up, and was not smoking, nor flowing . leaking just enough that I needed to add coolant after 500 miles or so. And dripping very slowly from the tail pipe.
Would go into the combustion chamber out the exhaust valve, into the cat, through the muffler and drip every 2 to 3 minutes at the tail pipe.
A very slow leak but still a leak in the cylinder heads. This stumped many " professional techs".
But With my 50 plus years experience with vehicle repair, and some mechanical intelligence and insight I got it corrected.
Yes I saw where you stated that you had a "DEGREE" in automotive repair.
So do I plus more than likely a few years more experience, I have seen things that many people have not even thought of happening to the automobile.
So as I said not necessarily!
ED
Old 04-02-2014, 05:41 PM   #15
Low Slope Roofing
Rewards Points: 114
So your saying the coolant went in to the exhaust....
Water Dripping From Circuit Breaker Box/Frayed Service Line Magnetic Electrical 6 02-03-2014 04:50 PM
Dripping noise from toilet drain redpoint5 Plumbing 18 10-30-2013 07:23 PM
Dripping noise from ceiling qb4006 Plumbing 3 01-18-2013 09:43 PM
New Muffler fitting bigjoe1986 Automotive Repairs 1 05-26-2012 10:19 AM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 04:05 PM
