Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-03-2012, 08:49 AM   #1
dragging sound while in motion
Hi, I have a 2007 Mazda 6 with 85,000 miles. Today when I put it in reverse it made a dragging sound (similar to muffler rubbing ground). The same sound was made going forward. Upon observation, nothing was dragging on the ground. Has anyone had any type of problem like this occur? TIA
frumdogg is offline   Reply With Quote
Old 04-03-2012, 09:34 AM   #2
DIY Enthusiast
sublime2's Avatar
Something stuck in one of the tires or came loose and is not rubbing one of the tires?
sublime2 is offline   Reply With Quote
Old 04-03-2012, 09:47 AM   #3
Experienced
Jackofall1's Avatar
If I were to venture a guess, you have an issue with your brakes. Ethier rusty disc from sitting, or worn pads which need replacing.
Mark
Old 04-03-2012, 10:20 AM   #4
Just had new brakes done last year, hope it is as simple as something wedged up there
Old 04-03-2012, 10:45 AM   #5
It is also possible one of the bolts has loosened and is rubbing the wheel. I would narrow it down to a side and pull the wheel.
Marty1Mc is offline   Reply With Quote
Old 04-03-2012, 12:47 PM   #6
Quite possibly a splash guard around one of the rotors. Depending on the type of wheels that you have, you may be able to see where it's rubbing against the rotor and correct the problem through the spokes.
Old 04-03-2012, 05:11 PM   #7
Afternoon of fun taking wheel apart found a stone stuck in between splash guard and rotor
Old 04-03-2012, 11:08 PM   #8
ukrkoz's Avatar
ask someone to walk next to your car when it moves, so that you can at least determine where noise is coming from.
ukrkoz is offline   Reply With Quote
No sound from speakers on rear projection tv chewizzle2k9 Electrical 4 11-06-2011 10:42 PM
Dual wiring for motion sensor security light ent Electrical 2 09-14-2011 03:00 PM
motion detector wiring (alarm systems) WendyS Electrical 3 02-25-2010 11:39 PM
Soundproof Windows BlueJello General Discussion 3 11-30-2007 06:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
