-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   dragging sound while in motion (http://www.diychatroom.com/f46/dragging-sound-while-motion-139110/)
frumdogg 04-03-2012 07:49 AM
Hi, I have a 2007 Mazda 6 with 85,000 miles. Today when I put it in reverse it made a dragging sound (similar to muffler rubbing ground). The same sound was made going forward. Upon observation, nothing was dragging on the ground. Has anyone had any type of problem like this occur? TIA
sublime2 04-03-2012 08:34 AM
Something stuck in one of the tires or came loose and is not rubbing one of the tires?
Jackofall1 04-03-2012 08:47 AM
If I were to venture a guess, you have an issue with your brakes. Ethier rusty disc from sitting, or worn pads which need replacing.
Mark
frumdogg 04-03-2012 09:20 AM
Just had new brakes done last year, hope it is as simple as something wedged up there
Marty1Mc 04-03-2012 09:45 AM
It is also possible one of the bolts has loosened and is rubbing the wheel. I would narrow it down to a side and pull the wheel.
DexterII 04-03-2012 11:47 AM
Quite possibly a splash guard around one of the rotors. Depending on the type of wheels that you have, you may be able to see where it's rubbing against the rotor and correct the problem through the spokes.
frumdogg 04-03-2012 04:11 PM
Afternoon of fun taking wheel apart found a stone stuck in between splash guard and rotor
ukrkoz 04-03-2012 10:08 PM
ask someone to walk next to your car when it moves, so that you can at least determine where noise is coming from.
