Doors Freezing Shut - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-05-2007, 02:49 PM   #1
Doors freezing shut
Winter has hit here in Western NY. My minivan's doors are freezing shut already. I tried cleaning and oiling the rubber seals with WD40. That didn't help. Any suggestions? It's rather annoying not being able to open your car doors on a 15-degree morning!
Thanks,
Tim
timp is offline   Reply With Quote
Old 12-06-2007, 08:55 PM   #2
I,m just across the border in Ontario, back when I worked in a garage I use to spray sicone lube on the rubber door seals, don't know if ever actually helped though.
stcwll is offline   Reply With Quote
Old 12-06-2007, 10:02 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I have used silicone as well and it does work. It may need to be reapplied before winter is out but it works well.
Old 12-07-2007, 12:44 AM   #4
Vaseline worked for me... and the car too!
Oldhouseowner is offline   Reply With Quote
Old 12-07-2007, 08:40 AM   #5
47_47's Avatar
Rewards Points: 44
Silicon, or a heated garage
47_47 is offline   Reply With Quote
Old 12-07-2007, 09:59 AM   #6
The heated garage is going to be my workshop...no cars in there please! (The heater is installed and the propane tank shows up next week. I can't wait!)
Thanks for the silicone suggestions. I need to pick some up anyway. The snow is clogging my snowblower something fierce and silicone should help it too.
Thanks all
Tim
Old 12-07-2007, 10:55 AM   #7
47_47's Avatar
Rewards Points: 44
Every year in the fall, I would clean my snow blower and empty a can of silicon into the auger and chute. I found that if I kept the snow blower cold, not in a heated garage, the snow doesn't stick too bad. Now I just use my Kubota.
Old 01-08-2008, 05:42 AM   #8
I have also used regular old car wax on shovels to keep the snow from sticking. Might also try Pam. I know the kids used it on their shoes when playing soccer to help keep the mud from sticking to the soles of the shoes.
oldgoat is offline   Reply With Quote
Old 01-08-2008, 08:02 AM   #9
NothingsLevel's Avatar
Baby oil works well too.
NothingsLevel is offline   Reply With Quote
Old 01-13-2008, 09:49 PM   #10
Rewards Points: 150
all work here,,,i like to get the food grade silicone so i can use it on boots ,jackets etc and no stains
comp is offline   Reply With Quote
Old 01-18-2008, 05:40 AM   #11
Put some of the silicone on my PU doors yesterday. I usually have some trouble with them freezing shut from snow or freezing rain. Will have to wait and see if it helps.
Pair of French Doors/ one is warped nyc1dxo Carpentry 8 04-28-2008 08:10 AM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 05:57 PM
French Doors - Locking Dummy Levers highflyguy Building & Construction 4 10-08-2007 11:35 AM
outswing patio doors philS Building & Construction 2 07-11-2007 02:39 AM
Attic Doors cyepsen Building & Construction 3 06-24-2007 07:47 AM
