Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-09-2011, 09:28 PM   #1
m1951mm's Avatar
Dodge Ram Van Burning Smell
Upon starting my van (2001 Dodge Ram Van, heavy tow package V6 (I think just over 61,000 miles) this evening I had a strong burning smell in the front cab part of the van. The smell was somewhat like burning vinyl, not quite as strong as a burning rubber smell. I checked the radiator and it was fine. There seemed to be no smoke coming from the engine itself or any burning smell under the hood. Any idea what I might be looking at?????.
Mickey
Fantasy Walls and Windows
m1951mm is offline   Reply With Quote
Old 12-10-2011, 07:38 AM   #2
raylo32's Avatar
You could have a seized air conditioning compressor clutch pulley or belt tensioner or belt idler pulley. Sometimes this can be intermittent but usually this will cause the belt to smoke and get thrown off.
raylo32 is offline   Reply With Quote
Old 12-10-2011, 11:41 AM   #3
ukrkoz's Avatar
wire insulation overheating or burning somewhere.
ukrkoz is offline   Reply With Quote
The Following User Says Thank You to ukrkoz For This Useful Post:
DangerMouse (12-12-2011)
Old 12-10-2011, 11:42 AM   #4
ukrkoz's Avatar
was cabin fan running?
Old 12-12-2011, 05:17 AM   #5
m1951mm's Avatar
Yes, the cabin fan was turned on when I started the van. It is always on. Should I have it turned to the off position when I turn off the ignition?? Should all vehicles have the fan in the off position when not in use??
Thanks for all the responses so far. I will get the van towed to the repair shop today.
Mickey
Old 12-13-2011, 09:51 PM   #6
ukrkoz's Avatar
reason I asked, if running, fan can suck in fumes from the outside. Or, produce the smell itself.
It does not matter if you leave it on or off when turning the engine off.
Old 12-14-2011, 04:16 PM   #7
Check for a plastic bag caught and burning on the exhaust, could be as simple as that.
D-rock is offline   Reply With Quote
Bad smell in crawl space. John_W General Discussion 28 10-20-2011 11:24 AM
Burning Smell from Washer Jupe Blue Appliances 4 10-11-2011 07:09 AM
Burning smell from furnace? scottyv81 HVAC 5 01-25-2011 09:49 AM
Central air burning smell intermittent boku HVAC 7 07-14-2010 10:23 PM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 09:29 AM
