-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   Dodge Ram Van Burning Smell (http://www.diychatroom.com/f46/dodge-ram-van-burning-smell-126129/)
m1951mm 12-09-2011 09:28 PM
Upon starting my van (2001 Dodge Ram Van, heavy tow package V6 (I think just over 61,000 miles) this evening I had a strong burning smell in the front cab part of the van. The smell was somewhat like burning vinyl, not quite as strong as a burning rubber smell. I checked the radiator and it was fine. There seemed to be no smoke coming from the engine itself or any burning smell under the hood. Any idea what I might be looking at?????:(.
raylo32 12-10-2011 07:38 AM
You could have a seized air conditioning compressor clutch pulley or belt tensioner or belt idler pulley. Sometimes this can be intermittent but usually this will cause the belt to smoke and get thrown off.
ukrkoz 12-10-2011 11:41 AM
wire insulation overheating or burning somewhere.
ukrkoz 12-10-2011 11:42 AM
was cabin fan running?
m1951mm 12-12-2011 05:17 AM
Yes, the cabin fan was turned on when I started the van. It is always on. Should I have it turned to the off position when I turn off the ignition?? Should all vehicles have the fan in the off position when not in use??
Thanks for all the responses so far. I will get the van towed to the repair shop today.
ukrkoz 12-13-2011 09:51 PM
reason I asked, if running, fan can suck in fumes from the outside. Or, produce the smell itself.
It does not matter if you leave it on or off when turning the engine off.
D-rock 12-14-2011 04:16 PM
Check for a plastic bag caught and burning on the exhaust, could be as simple as that.
