#1 |
Dodge Durango Rack and Pinion Bushing
Hello all!
I just failed my safety inspection on my 99 Dodge Durango The put down on the failure Rack and Pinion Bushing. The guy came in and said that appeared that a bolt was just loose, but he isn't allowed to tighten it. I put the wheel (right side) up on a jack and tried to wiggle the tire. It wiggled when I pulled the tire from the right side. but not much. I could hear and feel it. So can anyone one point me in the next direction? What can I do to fix this? Thanks in advance. |
#2 |
Oldguy
The Rack&Pinion is mounted to the crossmember in 2 places. Usually with a rubber bushing and a throughbolt or a rubber bushing and a strap. Check these mounting points.
If you think you can, or if you think you can't, you're probably right. ASE certified master auto tech, Retired. |
| Display Modes | |
