Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-10-2011, 08:45 AM   #1
Still Learning
dodge dakota 2006
I was in my partners truck and the weirdest think happened. He tur ed the truck on and it started making a knocking/clicking noise from the glove box... any ideas?
thehvacguy is offline   Reply With Quote
Old 08-10-2011, 03:40 PM   #2
ukrkoz's Avatar
dodge dakota 2006
relays. they have a lot of room available in dashboards to stick all kinds of stuff in there. on a common sense note, that's why windshields leaking above the rear view mirror location, should be fixed right away, or A LOT of electronics will fry.
or, he simply had some regular glove compartment junk in there, that made the noise due to vibration.
ukrkoz is offline   Reply With Quote
Old 08-10-2011, 10:11 PM   #3
dodge dakota 2006
Could be relay's, I would also check to see for blower motor noise, its also normally directly behind the glove box area.
D-rock is offline   Reply With Quote
The Following User Says Thank You to D-rock For This Useful Post:
ukrkoz (08-10-2011)
Old 08-17-2011, 08:35 AM   #4
Still Learning
dodge dakota 2006
Ok I will check the relays. Thanks guys. Yeah the noise only comes on for 10seconds at most when you turn on or off the a/c so that sorta makes sense
Old 08-20-2011, 09:56 PM   #5
dodge dakota 2006
He may have debris in the blower motor assembly.
Master of Cold is offline   Reply With Quote
Old 08-27-2011, 11:47 PM   #6
I'm Your Huckleberry
dodge dakota 2006
My boss just bought that same truck last week, alreay wants to get rid of it.
Doc Holliday is offline   Reply With Quote
Old 08-28-2011, 12:01 AM   #7
Still Learning
dodge dakota 2006
I might drive a dodge if it was given to me... I'm sorry for anyone who pays money for a truck like that...
Old 08-28-2011, 08:04 AM   #8
dodge dakota 2006
My dad owned a Chevrolet 1500, mid 90s model, that used to clunk, pop, and click for about a minute when starting and shutting the truck off behind the glove box.
A common Dodge problem is blend doors breaking at the hinges. Does all settings on the dial work? My boss had a Ram 1500 around the same year as this one and his made a similar noise when the blend door for the recirculated air stripped inside the hinge. The actuator would operate as its supposed to and try to turn the door to either open or close it and rod that makes up the hinge assembly was stripping inside the plastic.
bigdaddyII is offline   Reply With Quote
Dodge Dakota 2002 rear end rub ukrkoz Automotive Repairs 0 08-10-2011 03:42 PM
IRC 2006 Effective Date? EWen Building & Construction 0 01-23-2011 03:57 PM
Finding a copy of the 2006 International Building Code WFO Electrical 2 07-11-2009 08:21 PM
Dodge Truck 1610 CUB Automotive Repairs 1 01-08-2009 10:40 PM
Tax Credit: Buy new heat pump & handler now or 2006 toolmanwannabe HVAC 1 10-05-2005 12:41 PM
