Dodge Cummins Starting Problem 89 - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-18-2008, 06:09 AM   #1
Question
dodge cummins starting problem 89
Battery was dead wen trying to start truck after sitting 2 months charged the battery when I try to hook the battery back up there is clicking sound right away. no key in the truck at the time if yI turn the key on it acts as if the battery is dead the clicking sound is on the fender 12" from the battery some kind of termial is this bad or what might be going on
colddodger is offline   Reply With Quote
Old 12-21-2008, 06:40 PM   #2
Safe, Most of the Time!!
brokenknee's Avatar
Clicking sound is your solenoid trying to kick in to engage your starter. most likely your battery is shot and does not have enough power to turn your starter.
Check battery, voltage should be at least 12.6 volts. Voltage is only the first check for battery, bring battery to auto parts center for load test, most will do this for free. It is possible that the battery is good and you have something that is draining the battery.
OOPs went back and reread your post. You stated that the clicking was without the key in the ingintion. Disregard the above information.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
Last edited by brokenknee; 12-22-2008 at 05:55 PM. Reason: Poor reading comprehension :(
brokenknee is offline   Reply With Quote
Old 12-31-2008, 03:11 AM   #3
Rewards Points: 562
could be bad solenoid,starter or battery or a mirad of electrical wiring probs. I have a 91 cummins and its an electrical nightmare!! Has yours ever quit charging suddenly?? Is there a black molded plastic connection about 6 inches from alternator?? Friend stuck his finger between the wires there and laid back and PULLED as hard as he possibly could. that was 6 months ago and its still charging. I asked where he learned that trick,,he said its always better to be lucky than good!!!AND he smiled a big grin. When it quits NEXT time its gonna get cut outta there and wired direct. THAT part is unavailable,,,they say the truck is just too old!!!GRRR!!!!
Another trick I have heard is wires are too small for it too,,,some have rewired starter wire with 4-0 electrical cable,,,like a welder lead,,,covered in something like old garden hose!! A few strands of old wire get rattled and broke,,,rest cant handle it. Route it up and over so motor doesnt get it hot
Yep load test the battery,,if not it look to starter circuit. the clicking may be normal cause there is always something sucking juice,,like clock, puter, dome light?? etc. Your key isnt stuck on is it?? they get sticky too!!
4just1don is offline   Reply With Quote
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
91 Dodge Cummins probs-wiring 4just1don Automotive Repairs 1 12-05-2008 03:09 PM
2000 Toyota Avalon: starting and idling problem proofer Automotive Repairs 3 09-03-2008 09:29 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
