Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-11-2010, 02:09 PM   #1
DIY Question - 2000 Ford Explorer
Hi
I recently purchased a Ford Explorer (2000) - If someone can please tell me what electronical problems or challenges I'll be facing (fixing it the DIY way that would be great.
Thanks for your help/advice!
Hillel
diyford is offline   Reply With Quote
Old 01-11-2010, 05:21 PM   #2
Well...
Everything these days is "fuel injection" and computer controlled. But don't let that scare you.
If you have the right tools for the job, you can do quite a bit yourself.
In general for all vehicles...
The main tools for the job are a factory service manual set (order from dealer), a multimeter, a fuel pressure testing gauge, and a code reader.
Sometimes factory service manual sets are sold as separate books. You need to buy the complete set. There could be a basic factory service manual. Then an engine "fuel and emissions" book - this is misleading. Actually it is everything you need to troubleshoot engine problems. Not just emissions. And then an electrical wiring diagrams manual.
Some newer vehicle service manuals sets might be 4 volumes and a total of 2000 pages and everything is all mixed in together.
I frequently need ALL the books!
The factory service manual will tell you specifically what and where to test with the multimeter. Then depending on the results, it will tell you where to go from there. These books usually have sections on how to use a multimeter as well.
The computers in vehicles can figure out problems and alert you with the "check engine" light. Then you can read the code with an OBD II code reader. Then look for the code in the factory service manual, then it will tell you what to test. Usually with a multimeter.
And the factory service manuals will give you a list of things to service / check at various mileage intervals.
Newer vehicles have more than just an engine computer. There may be a anti-lock brakes computer, and air conditioning computer, an air bag computer, and a computer to roll down the windows!
But many "code readers" sold in auto parts stores will only read the diagnostic codes from the engine computer. If you are having problems with a "new fangled" electronic air conditioning system or the anti-lock brake system, these code readers would be useless!
There are newer "consumer" code readers on the market which will read more codes than just the engine computer codes. You may need to buy this off the internet to get the latest and greatest. Check around and ask on a Ford specific automotive forum.
The mechanics use code readers that cost $3000.00 and these can read ANY code from any computer in the vehicle. But that is not an option so far as I am concerned.
Here is a search of google.com for the words...
Ford OBD II code reader brakes transmission cart
http://www.google.com/search?hl=en&q...h&aq=f&oq=&aqi=
So far as the engine goes, there are electronic sensors which give input to the engine computer. Then the engine computer adjusts the fuel, air, and timing so the engine runs just right.
For example there is a sensor which checks the temperature of the coolant circulating in the engine/radiator. When it is cold, it will adjust the engine one way. Warm another way. And hot another way.
If that sensor is faulty and telling the computer the engine is cold when it is hot, the engine will not run right. And the way to check this sensor to see if it is working ok is to use a thermometer to measure the temperature, remove the electrical connector to the sensor, then measure the "resistance" of the sensor with the multimeter set to "ohms".
The factory service manual will give you complete instructions on how to test this.
And that is all there is to it. Just test different things as directed by the instructions. Then you only replace the part which needs replacement.
Some people don't read and will just start replacing parts. This is called "throwing parts at the problem". They spend a fortune doing this, then the problem turns out to be a loose ground wire somewhere and they didn't need to buy any parts!
Billy_Bob is offline   Reply With Quote
Old 01-12-2010, 03:38 PM   #3
gmhammes's Avatar
Starter will probably go at some point. (ford thing). Alternator as well. Both are not too bad to replace your self and together they may be a couple hundred bucks with cores. Just do you regular services and take care of it!
gmhammes is offline   Reply With Quote
Old 01-12-2010, 04:01 PM   #4
I've got a 2002 and I just got a recall notice. Don't know if it effects the 2000 or not, but you probably want to check. The notice said the truck would potentially spontaneously combust, even if not operational, and warned me not to park it in (or near) anything.
Haven't had any problems though, except the hood bumpers failed (little things that hold the hood up when closed.)
pyper is offline   Reply With Quote
Old 01-13-2010, 04:20 PM   #5
47_47's Avatar
My old 2000 F150 had the same recall, it was the something to do with the cruise control.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
94 ford explorer a/c clutch replacement explorer Automotive Repairs 1 09-06-2008 04:18 AM
94 Ford explorer air conditioning johntherault Automotive Repairs 5 04-17-2008 10:32 AM
Check Engine light Code P0430 Ford Explorer Mr Chips Automotive Repairs 4 04-09-2008 12:02 PM
2005 Ford Explorer Mystery Bell panhandlion Automotive Repairs 6 03-19-2008 10:27 PM
