Diffrence Between F150 And 250 - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-20-2013, 02:32 AM   #1
Rewards Points: 164
Diffrence between f150 and 250
I know most f150 are a 8cyl 302 but I have looked into f250 and it usually has a 351 in it, more power, but what the pros and cons in the two, I like the power in a f250 ?????
bostonwindows30 is offline   Reply With Quote
Old 08-20-2013, 05:34 AM   #2
DIY staff
Rewards Points: 7,174
250 has heavier running gear--springs----rear axle--brakes---(some times transmission)
If you haul heavy loads this is the truck----down side----harsher ride and less gas mileage due to lower geared rear end.
Old 08-20-2013, 05:36 AM   #3
Rewards Points: 164
On the 250 I like the bigger engine most fords I have seen a manual how come???
Old 08-20-2013, 05:41 AM   #4
DIY staff
Most truck are work trucks---a lot of people like a manual trans---that would be my guess----
I do know that the majority of PU trucks come with automatic---it is unusual that you are running into a lot of them with manual transmissions----
Old 08-20-2013, 05:42 AM   #5
Rewards Points: 164
I am looking at old models I like the way they look
Old 08-20-2013, 05:50 AM   #6
DIY staff
That explains the manual trans----as you can see from the responses here--a lot of people are loyal to the manuals---I've been driving since 1969---I love manual trans--the more gears the better---I even had a van with a 4 speed floor shift---
However, I switched to automatic in the trucks because many (most) people do not know how to drive and I was replacing clutches more often than needed---
And many employees simply could not drive a stick at all----so that was the end--from 1978 on all trucks were automatic---
Old 08-20-2013, 05:51 AM   #7
kwikfishron's Avatar
Rewards Points: 394
I have a 97 250 SHD with the 460, manual trans. 287,000 miles and still going strong. 10 mpg is it though, city, hwy, loaded or not 10 is all it gets.
kwikfishron is offline   Reply With Quote
Old 08-20-2013, 05:53 AM   #8
Rewards Points: 164
I bet you love that thing though huh??
Old 08-20-2013, 05:55 AM   #9
Rewards Points: 164
I want the 351 engine is that the same as 350 on a chevy??????
Old 08-20-2013, 05:56 AM   #10
DIY staff
It's easy to love a pick up----and I like the older styles too----
Old 08-20-2013, 05:57 AM   #11
DIY staff
351 is Ford equivalent of the GM 350----
Old 08-20-2013, 06:01 AM   #12
Rewards Points: 394
It's a good truck other than the milage. It's the old body style, 97 was the last year for that. They offered the old and new look that year. I only drive it when I need it though, I have a little Nissan 4x4 too.
Old 08-20-2013, 06:06 AM   #13
Rewards Points: 164
Difference between 302 and 351?????
Old 08-20-2013, 06:15 AM   #14
DIY staff
That is not a bad engine for a pick up---302 is better on gas---especially if fuel injected---plenty of aftermarket parts if you like to soup up the engine---
Will this be a pleasure ride or a hauling work truck? Daily driver or occasional use?
Old 08-20-2013, 06:19 AM   #15
DIY staff
I've has a lot of vans--mostly Ford----12 were 300 CID 6 cylinder--one was a 302 V8
One a 351 V8---
Never a mechanical problem with any of them----as you can see--I do like the 300/6
