Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-23-2009, 06:52 PM   #1
dash lights
2005 toyota highlander when i go 50 mph or more all the dash lights come on, ABS VSC, brake tire pressure sensor. Is it some kind of sensor acting up? nothing appears wrong when I am driving?
econdave is offline   Reply With Quote
Old 01-24-2009, 07:24 AM   #2
dash lights
If it's only abs, vsc and tire, not check engine, these systems are interlinked.VSC is stability control, abs you know, tires as well. Be cautious.These ones you don't want acting up at highway speed
Go to toyota nation.com and search your issue.
If the check engine lite was on I think it is more engine related. I have had check engine and VSC together as a result of a fowled air fuel ratio sensor. I changed the front bank AF on mine and all is well, but I had it decoded to pinpoint the source as there are three sensors on the car, 02 and AF, mine is a lexus RX300 same engine I think, 150,000 miles.
It is not uncommon that the check engine and VSC come on after refuelling if you overfill your tank or fail to ratchet the gas cap closed until it clicks.
Chemist1961 is offline   Reply With Quote
Old 01-24-2009, 10:12 AM   #3
dash lights
no check engine light but every other light possible. Brought it to dealer, will see what pans out
Old 01-25-2009, 06:27 PM   #4
dash lights
dealer says what I thought, a sensor in rear wheel, Charged me $124.00 to let me know. Says $364.00 to replace it. What a rip.
Old 01-28-2009, 06:48 PM   #5
dash lights
Try Toyotanation for help and hidden reacalll or TSB info.
How handy are you and can you get under the car safely?
Worst case ask him for a credit for the diagnosis if he fixes it.
Sounds like wheel speed sensor and possibley harness... both are apparently exposed. It's accessable but the trick is removing the rusted part without further damage.
from an insider...
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
New lights in basement CooperChloe Electrical 11 01-11-2009 12:22 PM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 09:25 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
