Darned Plastic Radiator Side Tanks - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-16-2015, 10:28 AM   #1
raylo32's Avatar
Rewards Points: 1,252
darned plastic radiator side tanks
This from my 1994 Camaro Z28 with 113k miles... my previous 1987 Z28 had the same failure at 115k miles (although it was only 7 years old at the time). Coincidence? New rad isn't that expensive but they really shouldn't be designed to fail, one would think.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 10-16-2015, 10:56 AM   #2
Brainbucket's Avatar
Rewards Points: 748
Coolant condition has a lot to do with cooling systems that fail. I flush mine every fall before it gets cold and make sure it can with stand the freezing temps. If coolant is not tended to, it turns into acid. You can measure the voltage by getting a multi-meter and putting one on the metal part of radiator and the other tip into the coolant in the neck of the radiator not touching the neck. I have seen 3 volts and the condition was like runny mud. It was eating the metal it touched. (Freeze plugs, water pump, gaskets, ect) The plastic tanks on radiators eventually just get old and crack or the seams leak.
If you first donít succeed, get a bigger hammer!
Brainbucket is offline   Reply With Quote
Old 10-16-2015, 11:06 AM   #3
raylo32's Avatar
Coolant is in good condition. Besides, acidic coolant should not affect the plastic parts. That's what always seems to fail
Old 10-16-2015, 11:31 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,044
Heat kills them.
They make small aluminum overflows that can be adapted.
Old 10-17-2015, 09:28 AM   #5
Bigplanz's Avatar
Rewards Points: 974
My radiators usually fail at the seam between the plastic and aluminum.
Bigplanz is offline   Reply With Quote
Old 10-21-2015, 11:56 AM   #6
Rewards Points: 756
any parts that pass 15-20 years on a car is very good, a lot of modern cars are junk after 10 years
carmusic is offline   Reply With Quote
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 08:40 PM
Bath Tub fix. Plastic Panel? crayola110 Remodeling 1 08-23-2012 04:13 PM
Plumbers Putty on Plastic index1489 Plumbing 0 03-19-2012 11:37 AM
What is the best glue for plastic? sukhenkoi Remodeling 3 03-02-2012 07:29 AM
Chrome paint on plastic Thurman Painting 3 08-24-2010 12:17 PM
