Cruise Control On '88 Suburban - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-29-2009, 06:53 PM   #1
Rewards Points: 77
Cruise control on '88 suburban
My cruise control went out on my '88 R10 Suburban the other day. It had been working fine until I got on the interstate and got her up to 70 mph. It started having problems holding the speed but I thought it was because I was going up a hill until it started happening on the level parts too. It finally quit on me when I hit the brake to let a semi in. It has not worked since.
I'm not sure where to start looking. If it is a matter of replacing parts, I should be able to do that myself as long as they are accessible.
Any thoughts will be helpful.
Thank you.
TJMS81 is offline   Reply With Quote
Old 04-29-2009, 07:35 PM   #2
If I had to take an educated guess, I would start looking at the transducer. That's the piece the throttle cable goes to. Check the wiring connections and vacuum lines at the transducer and verify that you have good vacuum going to it.. Without a diagnostic trouble chart, it's going to be hard to check for correct voltages at the various components. Probably not the brake switch because it wasn't a sudden failure. Could be the multifunction lever, but over the years, I found that the transducer was usually the problem.. Might be hard to find new parts for a system that old..
frazierdavidson is offline   Reply With Quote
Old 04-29-2009, 08:34 PM   #3
Safe, Most of the Time!!
brokenknee's Avatar
I don't have any experience with it but found this site.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
cruise control , suburban
Using a thermostat/relay to control baseboard heater perpetual98 Electrical 10 06-07-2009 11:57 PM
tapping into well control box? jjkrem Electrical 6 02-01-2009 11:03 AM
Well pump control box delema freeonthree Electrical 36 11-02-2008 09:55 AM
SEWER BACK UP, Which Flood Control Good????? diyjt5259 Plumbing 1 10-08-2008 10:44 AM
