Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-18-2012, 03:18 AM   #1
Corolla Won't Start..Possibly a cable failure?
We have a 2000 Toyota Corolla. I reversed the car up my driveway. There was some struggle when I placed the shifter in the "Park" position and I noticed that the car rolled forward so I engaged the handbreak. When I tried to start the car, nothing happens (the starter will not engage). I noticed that the moving down the shift was quite easy. I played around with the shifter while trying to start the car with no success. Then I finally gave up. At that point I noticed that I could not remove the key from the ignition. Your help will be greatly appreciated.
hawaiiboy is offline   Reply With Quote
Old 01-18-2012, 04:44 AM   #2
Busy DIYer
picflight's Avatar
Seems to be a fault with the switch on the gear lever. Try to bypass it and see if it starts.
picflight is offline   Reply With Quote
Old 01-18-2012, 07:08 AM   #3
If your car still rolls you are not in park, the starter will not engage in gear. Sounds like your shift cable broke if the lever moves real easy now.
cjm94 is offline   Reply With Quote
Old 01-18-2012, 08:47 AM   #4
Coconut Pete's paella!
CoconutPete's Avatar
Try putting in in Neutral - most non-push button start automatic cars I've driven also started in Neutral.
Whnen you said it still rolled down the hill in "D". Do you mean a foot or so, or did it want to keep going?
CoconutPete is offline   Reply With Quote
Old 01-18-2012, 02:00 PM   #5
Thank you all for your input. My hunch is that the shifter cable gave based on the inability to start the car and not able to the turn the key to the lock position to remove it from the ignition switch. What do you guys think? Also can anyway provide me pictures (diagrams) on how to remove the center counsel around the shifter? Aloha.
Old 01-18-2012, 06:22 PM   #6
Anyone knows where on the Internet I can buy at a fraction of the dealer cost a shifter cable for my 2000 corolla (4 speed)?
Old 01-18-2012, 10:16 PM   #7
Bigplanz's Avatar
Try rockauto.com
Bigplanz is offline   Reply With Quote
Old 01-19-2012, 03:50 AM   #8
I pulled the console off and found that the shifter cable slipped off the shifter. Do anyone know for my particular vehicle if it was held by a cotter or snap ring. Seems like it's the latter.
Old 07-25-2012, 02:01 PM   #9
Greeting I am now having the same problem with my 00 corolla. would you mind explaining how you where able to put the cable back on. Any help would be greatly appreciated.
roadkingryder is offline   Reply With Quote
Old 08-09-2012, 07:28 PM   #10
did you get this resolved? i have a 2009 corolla that the shift wont' go into park or reverse. Just want to know how you did it.
manny1234 is offline   Reply With Quote
Old 08-09-2012, 07:29 PM   #11
Old 10-26-2012, 09:56 PM   #12
Got it fixed. Used a lock washer from lowes.it is used to hold the wheel to an axle.
Old 10-26-2012, 11:38 PM   #13
Haverhill Trade 1965
Putting the shift lever on the wheel must make it difficult to drive. It sounds suspiciously like a push nut. You have to take them off with metric vise grips.
Duckweather is offline   Reply With Quote
Old 10-27-2012, 03:40 AM   #14
Well what I actually did to secure the ring end of the shifter cable to the stub out from the shifter was to put a snap washer secured by an axle cap. The axle cap is something that you will find that cheaply hold a wheel to an axle (eg a wheel barrel).
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 02:34 PM
Protect Cat6 cable near AC Power Cable? mfleming Electrical 5 10-31-2008 10:04 AM
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 09:00 AM
Transformer Help chcustom Electrical 28 12-10-2007 11:40 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
