Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-16-2012, 04:29 AM   #1
trekkiejt's Avatar
Converting Utility Trailer -> Boat Trailer
Hello all, I am converting a utility trailer to a boat trailer and want to keep it fairly original as I plan to be hauling some light stuff (besides the boat)with it also. Here is the trailer: http://www.northerntool.com/shop/too...duct_7262_7262. Adding a longer tongue is going to be the easy part, attaching the bunk board brackets is the hard part. Here is what they look like: http://www.amazon.com/Trailer-Roller.../dp/B002MYTV7U. The brackets affix with a U-bolt around the frame. The problem is that the frame on my trailer is in an open "P" shape (see below). My question is how do I attach these brackets without bending my trailer frame up? The loop of the bolt would have to go over the flap (the in side) and the bracket on the flat side (the out side) I think.
t_
| |_ (end view)
The boat by the way is a 12 foot flat bottom Jon boat. I am also adding DIY guards on the back and a DIY post up front to tie the boat to.
trekkiejt is offline   Reply With Quote
Old 07-16-2012, 08:46 PM   #2
World's Tallest Midget
Mort's Avatar
A metal sleeve in between the frame rails? If I'm picking up what you're throwing down, that would work.
Also, make sure to water proof everything, including the lighting. Marine grease the bearings, the whole bit.
Mort is offline   Reply With Quote
Old 07-16-2012, 11:50 PM   #3
trekkiejt's Avatar
I'm not sure what you mean about a metal sleeve between the rails. Please elaborate.
A friend suggested getting some short pieces of square iron tubing with an external diameter the same as the gap on the inside of the rail an the width of the "flap" to brace it. Is that really feasible?
Old 07-17-2012, 10:36 AM   #4
STAFF
BigJim's Avatar
You might want to beef the tongue up a little and run side braces, on that trailer it is a little flimsy.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 07-17-2012, 10:53 AM   #5
Mort's Avatar
I wasn't really understanding, so disregard.
Old 07-17-2012, 10:53 AM   #6
trekkiejt's Avatar
I think I could manage that. Are you sure I'd need to? The boat, gear, and add-ons are only about 150 lbs added to that 120 pound trailer.
Enclosed Utility Trailer Project jpn735361 Automotive Repairs 2 01-16-2011 11:10 AM
Utility Trailer Load Giles Off Topic 2 07-09-2010 12:40 PM
Removing paint from utility trailer pomelo Painting 1 02-26-2010 10:38 AM
Converting utility sink to standpipe? thebigsee Plumbing 7 08-17-2009 11:06 AM
DIY utility trailer or just buy? pcampbell Automotive Repairs 6 06-22-2009 03:07 PM
