-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   condensor fans (http://www.diychatroom.com/f46/condensor-fans-109090/)
MACK212 06-28-2011 02:34 PM
condensor fans
condensor fans running too slow on my 85 allegro it has 454 power horse engine...what do I need to do??
DangerMouse 06-28-2011 04:38 PM
Moved to Automotive section.
You'll get better responses when posting in the appropriate sections.
DM
ukrkoz 06-29-2011 12:45 PM
if we understood you correct, you have aftermarket electric fans installed, one for coolant and one for a/c? because a/c condensor is the only fan i am aware of. unless you have some cute-er set up?
if that's the case, start with checking voltage and amperage supplied to fan when it's running.
next, will be checking the fan itself. fans do go bad, you know.
unless you have clutch fan, like it used to be in the older vehicles, then clutch it getting tired.
or you have g'ol belt driven fan, then belt is stretched.
ukrkoz 06-29-2011 12:47 PM
oh, it's a motorhome... then yes, you may have fans all over the place. principle is the same though...
