A Cold Venture - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-23-2008, 10:28 PM   #1
Rewards Points: 336
A Cold Venture
It has finally dawned on me (after about a month) that there is no heat coming from the vents in my 2000 Chevy Venture. I thought it was taking a long time to put out the heat, but tonight, after letting it warm-up for 15 minutes and driving it to church and right back, there was still cool air coming out of the vents when we got home. We're told it could be either the heater coil or the thermostat. Could it be one of those and is it expensive to fix? Merry Christmas!
gma2rjc is offline   Reply With Quote
Old 12-26-2008, 01:02 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 602
Ayuh,...
It Could be either of those ideas, or any of many Other things....
Have you checked,+ Filled, if necessary, the antifreeze lately,...
Simplily a Low coolant Level can also possibly cause a No Heat issue...
Costs of repairs will be dictated by the prevailing rate for Shops in your area,+ What, Exactly is found to be the Problem....
Bondo is online now   Reply With Quote
Old 12-29-2008, 08:35 PM   #3
Rewards Points: 336
We took it to be looked at Saturday. The heater coil (?) had to be cleaned. Had an oil change, new wiper blades and the heater coil cleaned for about $100.
Thanks for your help. Have a Happy New Year.
Old 12-31-2008, 07:44 PM   #4
Glad you got it working. It's actually called a "heater Core" basically it's a smaller radiator like the one in the front of the vehicle, except that it's smaller and incased in the A/C-heater box under the dash.
AdRock is offline   Reply With Quote
Old 12-31-2008, 08:43 PM   #5
Rewards Points: 336
Thanks. It's nice to have it working again. Imagine if I went in there and asked the mechanic to look at the heater coil. He'd probably tell me it's not the heater coil, it's the glove compartment valve belt.
Have a happy New Year.
Old 02-10-2009, 07:39 PM   #6
I would guess you might have other problems, like a leaking intake gasket that is causing nasty stuff in your cooling system, your venture was probably low on coolant when you brought it in, but it is now full again for awhile.
oregondiy is offline   Reply With Quote
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
how cold is too cold for vinyl siding? THEBIGPUNN Building & Construction 1 11-22-2005 11:50 PM
