Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-14-2013, 08:58 PM   #1
clock loses juice/resets--
This is more aggravating than serious. Once every couple months when I leave for work at 4:30 AM when I crank the car the clock loses time and resets. It happens as I crank cause it resets to 1:00 right then and then works fine when set and run for another month or 2. Why would it lose contact so seldom and consistently?And NEVER at another time just this early time.?
4just1don is offline   Reply With Quote
Old 01-15-2013, 04:12 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Is this clock integrated into the radio? What manufacturer & model of car, along with year? Aftermarket radio, or radio that came with the car?
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 01-15-2013, 03:27 PM   #3
Electronics need a certain voltage to work. Below a certain voltage, electronics will stop working or reset/reboot.
Also when you place a large load on a battery, the voltage drops.
And when a battery is temperature cold like on a very cold day in the winter, it has less power.
With that said, it sounds like your car battery, when cold, and a large load is placed on it by starting the car, is going below the minimum voltage required to keep the clock working.
For example a fully charged car battery is 12.75 volts. When starting the car on a cold day, that voltage might drop to say 8 or 9 volts. And maybe the clock needs 9 volts to keep running?
A solution for that would be to make sure you have the correct size/capacity car battery installed. And to get a car battery which claims to have more starting power on cold days.
Another problem could be that there is something electrical always on - it drains the battery when the car is not running. And on that cold day that is enough to make it go below the voltage needed to keep the clock running. If that is the case, turn off whatever you have on (cell phone charger, etc.)
Billy_Bob is offline   Reply With Quote
Old 01-15-2013, 06:31 PM   #4
Guess I forgot to include specs,,,97 Olds Shiloute,,has 100K aprox.
Yes only happens on coldest mornings,,,this morn was twice in a row it happened.
Cranks good, lites are pretty dim on start for a second or two then goes regular bright
The air ride shocks on the back pump up off and on all night plus the red blinky lock lite blinks all nite
Thanks for the replies,,,btw my battery is about 3 or 4 years old,,,is this first sign of going bad? Work has zero tolerance for late or absence so it has to go. and sets outside in a cold lot often down to zero or 10 less
Old 01-15-2013, 07:44 PM   #5
gregzoll's Avatar
Again, factory or aftermarket radio?
Old 01-15-2013, 08:02 PM   #6
Could be the ignition switch; do you have many keys on your ring?
Old 01-16-2013, 05:39 AM   #7
sorry, factory radio, nothing fancy radio and cd player which dont use
And no, no extra keys just one
Old 01-16-2013, 11:42 AM   #8
gregzoll's Avatar
Batteries can go bad in 3 to 4 years. I had a problem with a Old's, that the battery connection was bad, and would create a problem with a open, that would cause the same situation. Replaced the ends on both the Positive & Negative leads, no problems after that.
It is a common problem with Old's of that generation, that GM even still had showing up in their later models from 2000.
Wolf MWC24 Oven Clock mst129 Appliances 2 11-04-2012 12:33 AM
GE/Hotpoint clock assembly timer shaft removal Spydey Appliances 0 03-04-2012 12:52 AM
Car Horn Alarm Clock carpenterty Electrical 13 01-04-2011 05:13 PM
Clock going cook coo farmerde Electrical 4 02-22-2009 09:26 PM
Clock segment burnt out n0c7 Appliances 2 11-06-2008 08:30 PM
