Chevy Power Stearing - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-06-2010, 04:18 PM   #1
chevy power stearing
I have a 1993 chevy silverado and i'm having troubles with the power stearing. when i turn the wheels the lines move like the pump is trying to pump but it doesnt make turning the wheels any easier an every once in awhile when i first start it the wheels move freely until the vehicle gets warmed up..
Coreystultz is offline   Reply With Quote
Old 10-06-2010, 04:50 PM   #2
Rewards Points: 304
Have you checked the fluid level?
polarzak is offline   Reply With Quote
Old 10-06-2010, 04:54 PM   #3
Yeah its full.
Old 10-06-2010, 05:45 PM   #4
Bigplanz's Avatar
Rewards Points: 990
Probably a bad power steering rack. What color is the fluid?
Get under the truck, disconnect the return line and put a pan under it. Pull the fuel pump fuse or the ignition coil wire so the truck won't start and crank it for a couple of seconds. If black gunk comes out, you have a bad rack. DON'T run the pump dry!
Check the rack mounting bolts. If one or more are loose, it can cause the problem you describe, but unless the pump itself is leaking, it is almost always a bad rack.
Bigplanz is offline   Reply With Quote
Devices to save on phantom power fetzer85 Electrical 7 12-04-2009 08:03 PM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 07:45 PM
Amp meter Results - SE Cable Bad or Power CO jamiedolan Electrical 30 01-23-2009 12:16 AM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
