Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-06-2010, 03:52 AM   #1
Red face
chevy cavalier rear defrost doesn't work!
Many weeks ago i looked for the problem soon abandoned it! Now I'm back, I checked the fuses, not it, checked the dash switch, it lights up, not it. Any thoughts? haven't tested wires attached to see if the current reaches back glass yet.
cncccc is offline   Reply With Quote
Old 01-06-2010, 07:12 AM   #2
47_47's Avatar
Use a 12 volt test light and check between the leads at the rear glass.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Old 01-07-2010, 02:59 PM   #3
Fixer-'til-broker
DIYtestdummy's Avatar
Check to see if the ground wire is connected to the lead on the glass. Also check each strip for continuity. Jump the wires from the switch DIRECTLY from a 12v power source - just because it lights up doesn't mean the switch isn't faulty.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 9 03-22-2011 09:40 PM
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 08:07 PM
Duct work in garage. flashme18 HVAC 1 11-08-2009 07:29 PM
Where are the "Carpenters" ???? wrldruler Carpentry 14 09-11-2008 08:37 AM
HVAC contractor ripoff! sekntonone HVAC 8 04-05-2008 08:15 AM
