Check Engine Light Code P0430 Ford Explorer - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-06-2008, 03:43 PM   #1
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Check Engine light Code P0430 Ford Explorer
Can anyone recommend a DIY troubleshoot for this check engine code
No noticable misfires. i have been burning some oil so i am wondering if its piston rings. just not sure how to check. The vechicle is a '98 Explorer XLT V8.
She is nearing 175,000 miles, so don't want to pump more money in her than i have to, but would love to pass inspection and get about 9 -12 more months out of the old girl
I wouldn't call myself a mechanic, but i have no problem doing the basics ( last job I did on her was replace both front wheel bearings, rotors, and pads)
Mr Chips is offline   Reply With Quote
Old 04-06-2008, 05:05 PM   #2
Oldguy
Rehabber's Avatar
The catalytic converter on bank #2 needs to be replaced
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 04-08-2008, 11:06 PM   #3
My Haynes Techbook does list that code so don't bother picking up this plastic shrink wrapped copy from your local parts store. Woulda been nice if Rehabber could have shared where he got his info because as you can read I own a copy of a book that isn't helpful. LOL. Good luck Cliff
UBoiler is offline   Reply With Quote
Old 04-09-2008, 10:12 AM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
i am a bit confused too, since the print out i got from autozone says the cat MIGHT need replacement, and it MIGHT have failed, due to oil getting into exhaust, vacuum leak, misfire etc... i was looking for a method to troubleshot and determine what needs to be done, as well as how the cause. Sure i can replace the cat, but if i have oil going into my exhaust, i imagine i will still fail inspection.
anyone have any insight?
Old 04-09-2008, 12:02 PM   #5
Oldguy
Rehabber's Avatar
Many things can cause a Cat to fail, one of them is mileage. A misfire will cause the check engine light to flash, so that isn't likely cause of failure. Excessive oil use (more than ! qt in 600 miles) or head gasket failure, I assume you would have given that information. My recommendation stands, Replace the Catalytic converter.
2005 Ford Explorer Mystery Bell panhandlion Automotive Repairs 6 03-19-2008 10:27 PM
