-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   Check Engine light Code P0430 Ford Explorer (http://www.diychatroom.com/f46/check-engine-light-code-p0430-ford-explorer-19555/)
Mr Chips 04-06-2008 02:43 PM
Can anyone recommend a DIY troubleshoot for this check engine code
No noticable misfires. i have been burning some oil so i am wondering if its piston rings. just not sure how to check. The vechicle is a '98 Explorer XLT V8.
She is nearing 175,000 miles, so don't want to pump more money in her than i have to, but would love to pass inspection and get about 9 -12 more months out of the old girl
I wouldn't call myself a mechanic, but i have no problem doing the basics ( last job I did on her was replace both front wheel bearings, rotors, and pads)
Rehabber 04-06-2008 04:05 PM
The catalytic converter on bank #2 needs to be replaced
UBoiler 04-08-2008 10:06 PM
My Haynes Techbook does list that code so don't bother picking up this plastic shrink wrapped copy from your local parts store. Woulda been nice if Rehabber could have shared where he got his info because as you can read I own a copy of a book that isn't helpful. LOL. Good luck Cliff
Mr Chips 04-09-2008 09:12 AM
i am a bit confused too, since the print out i got from autozone says the cat MIGHT need replacement, and it MIGHT have failed, due to oil getting into exhaust, vacuum leak, misfire etc... i was looking for a method to troubleshot and determine what needs to be done, as well as how the cause. Sure i can replace the cat, but if i have oil going into my exhaust, i imagine i will still fail inspection.
anyone have any insight?
Rehabber 04-09-2008 11:02 AM
Many things can cause a Cat to fail, one of them is mileage. A misfire will cause the check engine light to flash, so that isn't likely cause of failure. Excessive oil use (more than ! qt in 600 miles) or head gasket failure, I assume you would have given that information. My recommendation stands, Replace the Catalytic converter.
