Check Engine Light - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-26-2013, 01:08 PM   #16
r0ckstarr's Avatar
Rewards Points: 2,052
Originally Posted by gregzoll View Post
A 1996 should have a OBD2, since that is when they were widely adopted.
http://en.wikipedia.org/wiki/On-board_diagnostics
For the F150, OBD II officially started with the '96, beginning with vehicles manufactured ~ August '95. There are some '96's that were still OBD1.
That said, an easy way to tell is to just look at the diagnostics terminal.
OBD1
OBD2
r0ckstarr is offline   Reply With Quote
Old 04-26-2013, 04:10 PM   #17
PoleCat's Avatar
Rewards Points: 1,646
Mine was manufactured in Aug. 95 and has the newer socket style but it is located below the glove box.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 04-27-2013, 06:41 AM   #18
r0ckstarr's Avatar
I got an OBDII reader for my '96 Ford off of eBay about 5yrs ago for $20.00. It can read and clear the codes.
Old 05-07-2013, 12:56 PM   #19
Originally Posted by PoleCat View Post
I heard that it would go off on its own eventually. I drove to Indy and back yesterday and it remained on so maybe there is a hose I missed somewhere.
you have to drive and stop 3 times or 4, just driving and turning it off and then back on wont do it.
Hardway is offline   Reply With Quote
Old 05-07-2013, 10:11 PM   #20
How many miles total have you put on the car since you replaced the hoses? Worth considering might actually be running lean, or a sensor has failed. I agree with other though, step 1 is to clear the code with a 10 minute (minimum) battery disconnect.
teamcampreder is offline   Reply With Quote
Old 05-07-2013, 10:31 PM   #21
Its probley a 02 sensor code. Disconnect your battery for 30 minutes and then reconnect it, That will reset the PCM. I am a transmission mechanic and to unhook it and put it back on is ok. If i can help you in anyway I will.
waterlogged is offline   Reply With Quote
Old 05-08-2013, 06:07 AM   #22
PoleCat's Avatar
It was 125 mile run, 4 hour stop. 125 mile run back, overnight stop. 7 mile run, 30 minute stop, 7 mile run back overnight stop. etc.
Old 05-08-2013, 06:12 AM   #23
PoleCat's Avatar
Yeah I figure the disconnect is the easiest thing to do next. It runs perfect and if there is a lean condition it is slight enough that the tell tale exhuast aroma isn't there.
Old 05-09-2013, 01:11 PM   #24
English Only Please
BirdSlapper's Avatar
Rewards Points: 93
I may have missed it, but did you clean the Mass air sensor yet? Believe it or not, a dirty mass air sensor can trick a computer into all sorts of codes. If not, get some mass air sensor cleaner and security torx. Be very careful not to damage the sensor and don't touch the delicate wires inside the sensor!
BirdSlapper is offline   Reply With Quote
confusion with track light stephenbishop Electrical 7 03-10-2012 01:37 PM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 11:04 AM
Basic light wiring question speedster1 Electrical 3 11-29-2010 06:48 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Engine Light, Steering Fluid sweaty Automotive Repairs 3 08-09-2009 07:36 PM
